> Wont run after timing belt change
post May 29, 2011 - 6:37 AM
dctacoma
Joined Mar 20, '11
From Jacksonville Fl
Ok i changed my tbelt and thought everything was in time it cranks up but shortly after rpms drop down way far what is causing this 1 or 2 teeth off?
Replies (1 - 10)
post May 29, 2011 - 7:34 AM
more than likely mechanical timing.
post May 29, 2011 - 7:49 AM
dctacoma
Joined Mar 20, '11
i think my cam gear was off a few degrees. I put the belt on let the tensioner put tension on the belt but without force its loose? And if i force it the crank turns.
post May 29, 2011 - 9:46 AM
dctacoma
Joined Mar 20, '11
Im 99% sure everything is timed right but i crank it up it idles fine but sometimes when i give it throttle the rpms drop ?any thoughts
post May 29, 2011 - 10:03 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (dctacoma @ May 29, 2011 - 9:46 AM) *
How are you verifying that the timing is right. Did you disconnect any vacuum hoses, what all did you take apart.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post May 29, 2011 - 11:48 AM
dctacoma
Joined Mar 20, '11
only thing that has been apart is the timing area the crank is at 0, rotor button at 1, and cam pully at the v notch. and it still idles bad.
post May 29, 2011 - 5:48 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Not too sure which thread to respond to now....
Anyways, after you tighten down the tensioner is everything still lined up? I think you had that issue, correct?
post May 29, 2011 - 7:24 PM
Lone_Wolf
Joined Apr 22, '09
From Work
Same thing happened to me that's what I get for talking on the phone while changing the belt lol take the belt off and realign everything make sure no.1 Cylinder is at TDC.
Note: Make sure that the alignment of the v-notch is ±0.5 degrees from the 0 degree mark. This step ensures that the #1 cylinder is at top dead center (TDC, ie. piston at maximum height) when the piston is in compression and the exhaust valve is just closing. 2 crankshaft revolutions equals 1 system cycle.
http://www.6gc.net/forums/index.php?showtopic=57712
Its step 14 from the guide.
**If you can read this you are too close**
post May 30, 2011 - 9:38 PM
dctacoma
Joined Mar 20, '11
I noticed my crank timing gear is missing 1 tooth on the back part, not where the timing belt sits... will that cause any problems for the crank sensor?
post May 31, 2011 - 1:36 PM
dctacoma
Joined Mar 20, '11
Got A new gear and everything's running great
post May 31, 2011 - 5:31 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Odd...........well, good to hear it all back up and running.
Lo-Fi Version Time is now: August 29th, 2026 - 5:25 PM
