May 30, 2011 - 1:21 PM
Enthusiast ![]() ![]() ![]() Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
I didn't know where to post this stuff so I figured this would be a good place to start.
Well, I was wondering if anyone else has a sticky accelerator pedal? It feels like I have to press a little harder then needed to get any fuel into the engine, and then when it goes it revs a little harder then it should. I was wondering if anyone knows how to fix this so that I can smoothly accelerate? Also, being that my car is 13 years old I was wondering what are some things I can do to increase fuel effeciency, like one thing I'm going to do on my next refill is to buy a fuel injector cleaner, and on my next oil change I'm going to do a tranny and engine flush to clear out whatever gunk is in there, any one have any other idea's? And finally, how often should I change the oil pan seal, valve cover gasket, spark plug seal and fuel filter? I know it's a lot to ask but any help would be appreciated -------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
May 30, 2011 - 1:49 PM
Enthusiast ![]() ![]() ![]() Joined Jan 30, '11 From Albany, NY Currently Offline Reputation: 4 (100%) |
My pedal sticks some times as well, I haven't really bothered with it but I would htink some lube would help. As far as injector cleaners most don't work so I would do some research before choosing; I've herd good stuff from BG 44k so I would give it a shot. As for better mpg just the normal tune up (plugs, wires, air filter, oil change) if something is going then change it =)
-------------------- ![]() Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
May 30, 2011 - 2:31 PM
My pedal sticks some times as well, I haven't really bothered with it but I would htink some lube would help. As far as injector cleaners most don't work so I would do some research before choosing; I've herd good stuff from BG 44k so I would give it a shot. As for better mpg just the normal tune up (plugs, wires, air filter, oil change) if something is going then change it =) You mean like wd-40 the pedal? -------------------- Brand new 6gc owner! (sort of 2011)
May 30, 2011 - 4:33 PM
well its either the cable or the pedal I wouldn't use wd-40 in the car, I have special paintball lube so i use that sometimes
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:59 PM |
