Jun 2, 2011 - 4:06 AM
Enthusiast ![]() Joined Apr 27, '11 From Grimsby, Ontario. Currently Offline Reputation: 0 (0%) |
When I got the car... the battery soon crapped out on me. So I bought a new battery from Canadian Tire.
Under warranty and everything. But soon after it dies... I dont play my subs, unless my car is running. The only thing that stays on when my car is off, is a lil blue led at my rear view mirror. I checked the altenator.. and its putting out power... Although it kinda, SLIGHTLY goes down after a while. New Altenator? 200$ |
Jun 2, 2011 - 4:09 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
replace then
-------------------- God made man....
Everything else... Made in China ![]() |
Jun 2, 2011 - 4:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
do you have a voltage meter?
what you need to do it measure the battery power before you shut the car off at night. The next morning measure the battery again. If there is a big difference in volts. (drop below 12.60volts ) you have a parasitic drain on your car. second issue if that does not seem to be the problem would to check your cables and ensure there is no oxidation. |
| Lo-Fi Version | Time is now: August 28th, 2026 - 3:59 AM |
