> FS: 3rd gen DIY turbo kit - West Michigan, manifold, turbo and O2 housing - $250
post Jun 23, 2011 - 10:58 PM
scothaniel
Joined May 1, '03
From Michigan
For Sale: Stainless manifold, Mitsubishi TD05H-14B, Evo III O2 housing and O2 flange. $250 + shipping
** Note: this was run on a 96 Celica without A/C. Don't know if it would clear with A/C installed **
I created this setup after getting screwed on a knock off Greddy T67 kit (was supposed to be genuine) and I decided to make the best of it. I modified the manifold to use a standard Mitsu TD05 turbo flange and added an EGT port. Luckily whoever created this manifold used good quality stainless tube.
The turbo is an old 14B I had left over from my DSM days. The Evo III O2 housing (ie upper down-pipe ) is a standard upgrade for the DSM's as its larger and higher flowing than US-stock. This makes the rest of the down-pipe a simple 90* bend on our cars.
I planned to run the 14B for a couple of weeks/months while I broke in my engine, then upgrade to a big 16G or 20G turbo (cheap, 350+HP capable turbos readily available everywhere!). I ended up running this setup for about a year, and now I'm making a new crazy kit. Due to the small turbo size, spool up is crazy, but it runs out of breath quickly. The 16G or 20G turbo's would be perfect.
Basically selling for the value of the manifold and O2 housing. The turbo runs fine but is rather old.
PM or Email with questions.
Scott
West Michigan
Lo-Fi Version Time is now: September 22nd, 2026 - 1:51 PM
