> Timing belt change, What else?
post Jul 12, 2011 - 11:41 AM
jimmykay
Joined Jul 14, '08
From St. Louis
Well, I'm now at 165k miles and I think its about time I replace my original timing belt. So I figured i'm going to change my Power Steering, Alternator, and AC belt as well.
Using Azian's guide here http://www.6gc.net/forums/index.php?showtopic=57712
What else should I change? Do I need the two tensioners? Should I change the water pump since I'll already be down that far? Do I need to change anything else while I'm in there?
So all I need is 1 T belt, 1 PS/alt belt, 1 AC belt, and if I do the water pump, then 1 water pump, 1 thermostat, and 1 thermostat gasket as well?
Again, there's nothing wrong with the car, nothing is acting up or leaking or anything like that, but I just decided that my game of chicken with the timing belt is just about over and I'd rather not get stuck on the side of the road.
'99 Celica GT - Sold
'11 Mazdaspeed3
post Jul 12, 2011 - 11:50 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Yes doing the water pump is a great idea! You've got everything off of that side of the engine - you might as well!
post Jul 12, 2011 - 1:05 PM
jimmykay
Joined Jul 14, '08
From St. Louis
Right, thats what I thought too. But i didn't know if a water pump would show any signs of wear by making a noise or rattle or something.
Plus, I didn't know if the tensioners should be replaced too. Looking on 1sttoyotaparts, they're freakin expensive.
'11 Mazdaspeed3
post Jul 12, 2011 - 3:51 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
The oil seals for all the pulleys back there commonly go bad and leak, for the few extra bucks I'd change them out and save a future headache.
My F/S Thread!
Ferdi says (11:29)
post Jul 12, 2011 - 4:19 PM
jimmykay
Joined Jul 14, '08
From St. Louis
QUOTE (samir0189 @ Jul 12, 2011 - 3:51 PM) *
thats the kind of thing i'm looking for. Do you mean camshaft seals? I know the oil pump is down there, but i don't know if he has anything that protrudes out into the timing belt area that would need changed.
'11 Mazdaspeed3
post Jul 12, 2011 - 6:51 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
radiator hoses, thermostat, cam seal, crank seal, tensioner, idler, tensioner pulley, and check the accessory belt pulleys for play or noise.
post Jul 12, 2011 - 8:16 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
There is a seal behind the boil pump gear. Change that! And save your money on the alternator. If you don't need it don't change it. Its really to change out in the car so do it when u need to. I suggest pulling the engine to do all this. It will be worth it!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 13, 2011 - 10:52 AM
jimmykay
Joined Jul 14, '08
From St. Louis
QUOTE (Bitter @ Jul 12, 2011 - 6:51 PM) *
I think my radiator hoses are still good, thermostat is a given with the water pump. As far as camshaft and crankshaft seals, do you need to remove the cams and crank for them?
and are the tensioner pulleys needed? they're $120 for the two, and they weren't changed in the how to. just didn't know if they're subject to going out.
QUOTE (Smaay @ Jul 12, 2011 - 8:16 PM) *
The oil pump looks to be sold as a complete unit, so I can't find the seal. Sorry, I'm not pulling the engine. Thanks anyway. If I was going to go that far, it'd put something more fun in instead.
'11 Mazdaspeed3
post Jul 13, 2011 - 12:01 PM
samir0189
Joined Mar 8, '08
I think you need to remove the pulleys for the cam and crank seals, it can all be done without moving the engine. and the oil pump does have a seal.... cause mine was leaking and the dealer changed mine for me...
My F/S Thread!
Ferdi says (11:29)
post Jul 14, 2011 - 1:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
front mail seal, or oil pump housing seal.
Lo-Fi Version Time is now: June 24th, 2026 - 9:33 PM
