> Engine RPM vs Vehicle Speed
post Jul 13, 2011 - 2:20 PM
azian_advanced
Joined Apr 18, '05
From Calgary
Here's a graph of a 6gc with an S54 (ST202 non-superstrut and all ST204), C52 (AT200), E56 (ST202 with superstrut), E153 (swapped camry v6 or MR2 turbo tranny), and E154F (ST205) gearboxes showing the vehicle speed for various engine speeds for all 5 gears on stock wheels & tires.
mph
km/h
For those of you running aftermarket wheels & tires, you can download the .xlsx (Microsoft Excel 2007+) file from here: DOWNLOAD (80 KB)
the file's protected so to edit the spreadsheet, click on the "Review" tab in Excel, click "Unprotect Sheet" and enter the password "6gc". then you just need to input your wheel & tire sizes in the correct tab (ie. S54, C52, E56, etc.), press Enter, and the graphs will update themselves.
the estimate assumes no deflection in the tires. in other words, the tires are solid and don't conform to the road (ie. no weight on the tires). so this is an over-estimate of the actual speed as the deflection in the tires depends on the tire stiffness, sidewall profile, type of tire, vehicle weight, etc.
This post has been edited by azian_advanced: Jul 23, 2011 - 10:20 PM
Replies (1 - 15)
post Jul 13, 2011 - 3:21 PM
Hafkai
Joined Dec 9, '05
From Germany
Nice table! But you got a little error in it.
The calculation for the tire diameter should look like this =(I4*25,4)+2*(E4*G4/100) instead of =(I4*25,4)+(E4*G4/100) smile.gif
post Jul 13, 2011 - 3:34 PM
playboymma
Joined Jan 7, '11
From Mena, AR
what would be perfect is if you could show the graphs you have on each tab instead of one merged graph to eliminate all confusion
I went full retard once, too. Its OK.
post Jul 13, 2011 - 4:15 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (Hafkai @ Jul 13, 2011 - 2:21 PM) *
QUOTE (playboymma @ Jul 13, 2011 - 2:34 PM) *
original post updated.. thanks for the feedback guys
post Jul 13, 2011 - 4:45 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Wow this is pretty awesome..thanks for sharing
(\__/)
post Jul 13, 2011 - 6:02 PM
playboymma
Joined Jan 7, '11
From Mena, AR
STICKY VOTE
post Jul 13, 2011 - 8:50 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
nice, always wondered this
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Jul 15, 2011 - 10:34 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Hell yes, I've got 17x7.5 wheels and 215/40/17 tires, and all my values are lower compared to the graph.
June '12 COTM
'95 AT200
post Jul 15, 2011 - 1:04 PM
Neon90424
Joined Jan 19, '11
my 205 goes to about 50-60 km/h not 80km/h
post Jul 15, 2011 - 7:27 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Yeah, I'm pretty damn sure that when I hit 7000 RPM in 1st gear in my ST205, I'm about 4km/h faster than what you have -- 35 miles = 56.32704 kilometers
Forget about tyre size too, the speedo is pretty dead on when you have factory sized tyres , 1 size up is about 1-2% under reading, 1 size down is about 1-2% over reading
This post has been edited by delusionz: Jul 15, 2011 - 7:28 PM
Mike W
269awhp / 273ft-lbs
post Jul 15, 2011 - 8:04 PM
delusionz
Joined Feb 11, '08
2nd gear hits dead on 100km/h in 2nd at 7000
Mike W
269awhp / 273ft-lbs
post Jul 15, 2011 - 9:38 PM
Neon90424
Joined Jan 19, '11
my bad didnt realize the chart went to 8000
post Jul 22, 2011 - 4:17 AM
Rusty
Joined Nov 5, '07
From New Zealand
Great stuff, will add this along with others to the stickies tomorrow.
could you also add the E56, I can pm you the ratio's of you need them. and maybe also the E153?
post Jul 22, 2011 - 12:52 PM
azian_advanced
Joined Apr 18, '05
From Calgary
post Jul 22, 2011 - 2:29 PM
Needles
Joined Nov 18, '10
From montreal
i have the e153 mr2 and at 120 km/h i run 3800 rpm in 5th gear
post Jul 23, 2011 - 10:28 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (Rusty @ Jul 22, 2011 - 4:17 AM) *
update: added the E56 and E153 to the OP
Lo-Fi Version Time is now: September 17th, 2026 - 8:27 PM
