Jul 15, 2011 - 10:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
So doing a slight tuck on the motor and relocating some vac lines, i am removing the factory boost controller but, can i also remove these two plugs?
![]() And this black vac line here goes to the intake mani, therefore the cap can just be placed on the other side correct? ![]() now this one, should be easy, the two lower lines in the picture are coolant lines correct? therefore they can be removed and the lines bridged together without issue? and that larger hose (from what i measure 1/2" ID that can be capped at the sensor on the tb or no? ![]() -------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Jul 16, 2011 - 1:24 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
Those coolant lines are the throttle body coolant lines. If you live somewhere thats really cold then keep them, but if its reasonably temperate get rid of them, you can loop them back where they attach to the motor, much cleaner that way.
-------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Jul 16, 2011 - 7:33 AM
anyone know about the other lines?
Jul 17, 2011 - 10:20 AM
Anyone?
Jul 17, 2011 - 10:31 PM
Keep the lines to the power steering pump, its been a long time since my motor was that stock i cant remember where those lines (and the associated sensors) go.
| Lo-Fi Version | Time is now: September 1st, 2026 - 7:05 PM |
