> 2nd gen 3sgte problem thread...
post Jul 16, 2011 - 10:28 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
first off sorry if this is a repost. i put my 2nd 3sgte back together tonight. went to start it and found that it doesn't hold an idle. if i give it gas every thing is fine, but when i let off the pedal idle falls and eventually the car dies.
eliminated the neutral safety switch as well as boost/vacuum leaks as being the problem. not a fuel issue, or battery concern either! i have two or three grounds in the engine bay. wanna say it's the air flow sensor. any suggestions, or advice is appreciated!
This post has been edited by garin: Jul 24, 2011 - 10:26 PM
Replies (1 - 15)
post Jul 17, 2011 - 12:35 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
could the the MAF or the idle air control valve
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 17, 2011 - 9:26 AM
Is your mechanical timing set properly?
post Jul 17, 2011 - 10:24 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
i was thinkin along those lines.
post Jul 18, 2011 - 12:04 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
ok so i got a different afm on the car. seemed to have helped, but the car eventually dies still. looking into the iac valve/ throttle position sensor. what kinda current should this have to assure that it is good?
post Jul 18, 2011 - 10:10 AM
QUOTE (garin @ Jul 18, 2011 - 1:04 AM) *
It sounds like you have a loose coupler or some type of air leak in the system. Did you recently disconnect any vac lines or intercooler piping? The 2nd gen is very sensitive to these things and will not idle if there is an air leak somewhere.
post Jul 18, 2011 - 12:35 PM
... and as for those sensors, you can just unplug them. If they are somehow causing an issue, unplugging them will make the car run/idle at its default values. But 99% of the time (assuming you didn't mess with the timing belt), this sort of thing is caused by an air leak in the system.
post Jul 19, 2011 - 7:44 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
Mine does the same thing, my iac isn't doing anything and a new one isn't a cheap date... $200 list price for me from napa, or car quest. I just set idle by setting the idle screw to about 900 rpm
2nd Gen 3s-gte.... It lives!
97celiman
post Jul 19, 2011 - 11:48 PM
QUOTE (Stambo @ Jul 19, 2011 - 8:44 PM) *
He actually fixed his issue but I guess didn't update here. It was just a vac leak.
If you really do need an IAC, I can get you a toyota one for well under list price.
post Jul 21, 2011 - 12:22 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
well i mean cost price w/e. Just went to the next thing since he said he ruled out boost/vac leaks. Good to hear its done tho
97celiman
post Jul 24, 2011 - 5:03 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
oh yes thanks for the update lagos! it was boost leak. no i have my next issue. my downpipe cracked. i broke two manifold studs while taking it out. any suggestions, or special techniques for removal?... i got a ceramic coated berks on the way!
post Jul 24, 2011 - 5:56 PM
QUOTE (garin @ Jul 24, 2011 - 6:03 PM) *
If there is anything sticking out of the head, stud remover, and a propane torch, lots of pb blaster, and patience will get them out, if they are flush with the head, it gets harder.
post Jul 24, 2011 - 10:09 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
they do stick out! i figured heat and some pb would work. i didn't know if anyone had any special tricks. thanks manny!
post Jul 25, 2011 - 8:33 PM
QUOTE (garin @ Jul 24, 2011 - 11:09 PM) *
I dont bother taking off the exhaust manifold for that exact reason. I just take the turbo off the manifold. Its actually not that hard to do.
post Jul 25, 2011 - 10:11 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (lagos @ Jul 25, 2011 - 9:33 PM) *
one of the nuts to get the turbo off was stripped! d'oh.
post Jul 30, 2011 - 9:24 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
got one stud out. one more still stuck. i used propane. pb blaster and craftsman bolt out.
Lo-Fi Version Time is now: July 29th, 2026 - 8:17 PM
