> Clutch question
post Jul 17, 2011 - 8:25 PM
Dangercart1
Joined Dec 8, '09
I have a beams redtop and a s54 trans to go with it, the only problem is I don't know what clutch to get, anybody know?
post Jul 17, 2011 - 9:08 PM
i know 3s lightweight FW then OEM Beams disk, st185 pp, and s54 tob and a wicked cool SS braided clutch line
beams oem clutch is available..
post Jul 19, 2011 - 4:15 PM
S8S8
Joined May 9, '09
From Brisbane, Australia
I'm not sure where you're located, but here in Australia I was just able to order a standard 3SGE clutch kit which worked perfectly. The kit was not Beams-specific, as we didn't get the Beams engine here either.
post Jul 19, 2011 - 4:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
he is using the stock GT (5S-FE) trans, that means he needs the 5S-FE disk. im 99.9% sure the pressure plates between the 2 are the same. but i know who can give you teh 100% correct answer. Andy at Southbend Clutch. call him, he is in the import department. tell him i sent you and you will be good to go!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 19, 2011 - 7:16 PM
Dangercart1
Joined Dec 8, '09
Thanks a lot for the help guys a lot of good information
post Aug 1, 2011 - 12:20 AM
black93hardtop
Joined Feb 6, '11
From Chicago
I would use a 3s flywheel and clutch but change the center hub on the clutch disc to your S54, removing the E153 hub. Hybrid clutch. You can special order this (depending on manufacture) and its more common than you think.
Thanks,
Brian
Lo-Fi Version Time is now: May 16th, 2026 - 1:01 PM
