Jul 21, 2011 - 12:41 AM
Enthusiast Joined Mar 19, '11 From Claresholm Ab Canada Currently Offline Reputation: 0 (0%) |
I have been a member for a while. There is a lot of usefull info here and I enjoy reading everyones ideas amd suggestions.
I have a problem with my ST205 I have been looking online for a while now. I found some ideas for a fix here but with no sucsess. I have found lots of info on Intercooler(IC) problems. I'll lay out the problem My relay mounted off the rad is buzzing and sending my car in to limp mode. I have checked the ic sensor on the top of the ic. It works fine. I bridged the sensor. The relay still buzzes. I have checked the pump and it works fine. I replace the wire from the ecu (int) intercooler pin from the ecu all the way to the relay. If I ground out that wire the pump will stay on I have a feeling its a short in the system. I just can't track it down. There is a lot of info on the net but none of it seems to have this same problem. There are a few ways to bypass the system but i would rather fix it not bypass. I found a bypass link here http://www.6gc.net/forums/index.php?showto...rt=#entry637791 Any help will be great Thankyou |
mrrift ST 205 Intercooler problems Jul 21, 2011 - 12:41 AM
delusionz Any chance you could take a picture and circle wha... Jul 21, 2011 - 12:52 AM
mrrift QUOTE (delusionz @ Jul 21, 2011 - 12... Jul 21, 2011 - 1:50 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 3:14 AM |
