> Front Rotor questionssssss
post Jul 28, 2011 - 11:14 PM
mmmchocolate
Joined Nov 18, '08
From Idaho
Searched for awhile, couldnt find what i need....
my question is,
when i go to replace my rotors, do i have to remove the bearings and ****, or does the rotor just slide off...per say?
Replies (1 - 5)
post Jul 28, 2011 - 11:17 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Remove the calipers and the rotors should just come off. Might need some light banging in case there is any rust, but with no tire or caliper to hold it on that rotor should slip right off.
post Jul 28, 2011 - 11:18 PM
mkernz22
Joined May 10, '10
From MA
post Jul 28, 2011 - 11:19 PM
mmmchocolate
Joined Nov 18, '08
From Idaho
QUOTE (KAOS @ Jul 28, 2011 - 10:17 PM) *
dope. thats the answer i was looking for.
thanks man
post Jul 28, 2011 - 11:27 PM
KAOS
Joined Apr 18, '06
QUOTE (mkernz22 @ Jul 28, 2011 - 10:18 PM) *
What bracket are you talking about??
post Jul 29, 2011 - 1:26 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The caliper bracket. AKA torque plate.
Bare caliper is the hydraulic portion only. Semi-loaded caliper is caliper and bracket. Fully-loaded caliper is caliper, caliper bracket, and pads.
Easiest way to get to the rotor is to remove the bracket from the knuckle, since the caliper attaches to the bracket. Make sure not to leave the caliper assembly hanging by the hose, find something to rest it on or string it up to keep the tension off the flex line.
Lo-Fi Version Time is now: March 23rd, 2026 - 8:01 PM
