> Oil Gasket, Oil Gasket Change
post Jul 30, 2011 - 1:57 PM
ivan77cb
Joined May 23, '11
From CaLiFoRnIa
does anyone does know how to change the oil gasket because my car is leaking a lot of oil
Replies (1 - 3)
post Jul 31, 2011 - 4:32 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Oil pan gasket? Not a solid gasket, it's sealed with Toyota black FIPG (form-in-place gasket) -- which is a step up from Permatex and the like.
Valve cover gasket? Buy replacement, with grommets for the spark plug tubes (will be included if you buy from Toyota), remove valve cover by undoing the nuts around the spark plug tubes. Carefully scrape the mating surfaces clean with something such as a plastic razor -- don't use metal or you risk damaging the surfaces -- then replace gasket while applying a little FIPG to the corners around the cam.
Oil pump seal? Too long an explanation, either get a repair manual or a mechanic.
post Aug 10, 2011 - 8:07 AM
Hanklybu
Joined Aug 10, '11
From USA
post Aug 11, 2011 - 11:12 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Hanklybu @ Aug 10, 2011 - 8:07 AM) *
Toyota should have had to recall all cars with that POS oil pump cover seal.
Lo-Fi Version Time is now: September 3rd, 2026 - 11:29 AM
