Closed TopicStart new topic
> Gas Pedal Stuck!!!! Danger!!!!, 1997 Toyota Celica GT Gas Pedal Stuck..
post Jul 31, 2011 - 11:30 AM
howie_vang
Joined Jul 11, '08
From Cali
AS OF 07/30/11 AT 7PM I WAS COMING HOME FROM A PARK WITH 3 OTHER PEOPLE IN MY CAR. AS SOON AS WE EXITS THE ENTRANCE MY CAR STARTING SPEEDING REALLY FAST LIKE SOMEONE HAD JUST SLAMMED THEIR FOOT ON MY GAS PEDAL...OH BOY I WAS IN DEEP TROUBLE...I HAD TO SHIFT GEARS SO QUICK SO THAT I WON'T HIT THE REDLINE AND BLOW MY ENGINE.. I PULLED OVER AND SET MY CAR ON NEUTRAL BUT MANN MY CAR WAS STILL REFFING SO I TURNED OFF MY ENGINE...TURN MY ENGINE BACK ON AND IT DID THE SAME THING..AFTER A FEW ATTEMPTS OF TRYING TO FIGURE OUT WHY MY CAR IS DOING THAT.. I CALLED A FRIEND AND HE TOLD ME TO UNPLUGGED MY BATTERY FOR 10 SECS. AND PUT IT BACK ON.. AND IT WORKED...OH BOY SO I THANKED THE LORD BECAUSE NOBODY WAS HURT AND LUCKILY THERE WEREN'T ANY CARS DURING THAT TIME...
WHAT COULD HAVE BEEN THE PROBLEMS, ANYONE KNOW OR HAS BEEN THROUGH THE SAME?
post Jul 31, 2011 - 11:36 AM
mak5603
Joined Oct 20, '08
...seriously, I'm not even going to read that.
2014 Toyota Rav4 XLE
post Jul 31, 2011 - 12:00 PM
richee3
Joined Jun 29, '08
From Denver
The caps lock really isn't necessary. As far as your friend unplugging the battery, that's a moot point since the Celica uses a drive-by-cable throttle, not drive-by-wire. It's a mechanical system so odds are if your throttle cable stuck once, it could stick again. You need to check that out. It could be a burr on the cable.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 31, 2011 - 12:01 PM
TAKE IT TO TOYOTA TO HAVE THE CAMRY PEDAL AND THE PRIUS ECU CHANGED..
BUT HURRY TIME IS RUNNING OUT ON YOU.
YOU MAY STILL QUALIFY FOR 0% DOWN AND 0 PAYMENTS FOR 60 MONTHS ON A NEW TOYOTA CARINA.
post Jul 31, 2011 - 12:41 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (njccmd2002 @ Jul 31, 2011 - 12:01 PM) *
June '12 COTM
'95 AT200
post Jul 31, 2011 - 12:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
OHH GAWD NOO NOT THE CELICAS TOOS!!!!!!
NO ONE IS SAFE!!!!!
YOU SHOULD HAVE turned the key off maybe? yeah that works.
clean up your throttle body and cable. build up can make it stick... but its not gonna ALLL OF THE SUDDEN ACCELERATE.....
you must have floored it, and since its dirty or gummed up, it stuck.
post Jul 31, 2011 - 1:38 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
THIS IS A PROBLEM YOU CREATED BY IGNORING A SICKY GAS PEDAL WHICH CAN BE CAUSED BY A DIRTY BUTTERFLY VALVE IN THE THROTTLE BODY A BAD THROTTLE CABLE OR IN RARE CASES IT HAS BEEN A DIRECT RESULT FROM POSTING IN ALL CAPS AND IGNORING THE USE OF PUNCTUATION
EDIT DANGER WILL ROBINSON DANGER
This post has been edited by 95CelicaST: Jul 31, 2011 - 1:41 PM
**** Photobucket
post Jul 31, 2011 - 1:52 PM
travisxcore
Joined Mar 24, '11
From 704
post Jul 31, 2011 - 8:02 PM
cheela
Joined Feb 2, '07
From Berlin, WI
L
O
L
post Jul 31, 2011 - 8:12 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
definitely check your throttle cable! you dont want to damage your motor, or hit someone.
oh and ibtl
post Jul 31, 2011 - 8:15 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
post Jul 31, 2011 - 8:16 PM
Lone_Wolf
Joined Apr 22, '09
From Work
VTEC JUST KICKED IN NOOB !!!!!!!!!!!!!!!!!!! Seriously by reading your original post nothing adds up we don't have drive by wire so resetting the battery would do you no good if your gas pedal was stuck.
**If you can read this you are too close**
post Jul 31, 2011 - 8:55 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
wow that made me sick to think there are poeple out there like this lol.. but it makes for good reading!
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Jul 31, 2011 - 9:03 PM
this is fun.
post Jul 31, 2011 - 10:00 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
^+1
~bloodMoney
post Jul 31, 2011 - 10:18 PM
Fun, this is.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Aug 1, 2011 - 1:46 AM
pandakid
Joined Feb 12, '06
From Fresno CA
clean the throttle plate with the throttle body cleaner.maybe the gunk is getting the throttle stuck and check the cable.
post Aug 1, 2011 - 2:59 AM
Rusty
Joined Nov 5, '07
From New Zealand
Lo-Fi Version Time is now: August 28th, 2026 - 9:33 AM
