Jul 31, 2011 - 10:12 PM
Enthusiast ![]() Joined Jun 15, '11 From Orangeville, Ontario, Canada Currently Offline Reputation: 4 (100%) |
ok, i'm trying to take the riser blocks off from the spoiler. Each side has these two things that look like rivets. Do i need to drill them out to take the rises blocks apart from the spoiler?
thanks, Martin |
Aug 1, 2011 - 7:38 PM
nobody took apart their gt4 wrc spoiler?
This post has been edited by martinmr2: Aug 1, 2011 - 7:39 PM |
Aug 1, 2011 - 8:44 PM
gimme a call man, I'll take a look at it for you. I'm around tomorrow and on the weekend.
Aug 2, 2011 - 5:47 PM
hey,
i'll call you on the weekend..... thanks, Martin |
Aug 3, 2011 - 3:30 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
my spoiler blocks have holes on the bottom where you can fit a tube thingy to unscrew the little bolts or studs or whatever the hell it is...
Aug 3, 2011 - 5:30 PM
my spoiler blocks have holes on the bottom where you can fit a tube thingy to unscrew the little bolts or studs or whatever the hell it is... thanks, i took off the 2 10mm bolts and the 3 little scews that keep the bottom cover on. Just need to figure out the studs / rivets part...... Martin |
Aug 4, 2011 - 7:33 PM
Metal or plastic rivets? I'm thinking they pull right off with some pressure.
Aug 4, 2011 - 8:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
yeah, they have one way screws, its a tough one ...
-------------------- Mike W
Aug 4, 2011 - 10:11 PM
looks like metal ( aluminum). I'm thinking about drilling them out, than use bolts to keep the 2 parts together. Also when i took out the 2 10 mm bolts, i noticed that the nuts on the back side became lose and are now rattling in the spoiler. I have to take it apart and do it properly......
Martin |
Aug 4, 2011 - 11:20 PM
perhaps a smalll stud extractor
they must be m6 in there ... -------------------- Mike W
Aug 27, 2011 - 6:43 PM
well, i took care of it today. Drilled out the top caps of the studs until they fell off. Then i just lifted off the risers and removed the threaded studs from the spoiler end by hand. Not too hard, just took some time. Will put together with regular bolts. Have to now prep and paint the spoiler, than drill the hatch for the new bolt pattern......
Martin |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 4:31 AM |
