Aug 1, 2011 - 3:41 PM
Enthusiast ![]() ![]() Joined Oct 11, '06 From calgary Currently Offline Reputation: 5 (100%) |
so for a awd car, i know its bad to run different size tires and all four must match.
What about if you run same size tires but the rims in the rear will be 17x9 with 44+ offset and front will be 17x8 with 32+ offset tires will be 225/45/17 all around. the backs are a little more stretched but when I measured the diameter of the whole wheel, its only different by a 4 millimeters. Getting conflicting reports on this, don't want to mess up my diff. can it be done? |
black13 different offset on awd Aug 1, 2011 - 3:41 PM
stephen_lee ur diff may survive, but the fact is, that 4mm wil... Aug 1, 2011 - 4:08 PM
Cuts_the_Pilot Run the same width rim, and same tyre front and re... Aug 2, 2011 - 4:26 AM
black13 so sad i have a nice set of rims with rubber and I... Aug 3, 2011 - 12:17 AM
Cuts_the_Pilot You could measure the finished rolling diameter an... Aug 3, 2011 - 3:08 AM
delusionz i was running a stagger with 15mm spacers in the r... Aug 3, 2011 - 5:01 PM
black13 QUOTE (delusionz @ Aug 3, 2011 - 4:0... Aug 4, 2011 - 11:59 PM
stephen_lee different offsets wont cause an issue. different s... Aug 7, 2011 - 8:09 PM
Cuts_the_Pilot QUOTE (stephen_lee @ Aug 7, 2011 - 6... Aug 7, 2011 - 9:28 PM
stephen_lee lol i was the first to reply with basically the sa... Aug 7, 2011 - 9:34 PM![]() ![]() |
| Lo-Fi Version | Time is now: June 24th, 2026 - 2:18 AM |
