> camber bolts
post Aug 6, 2011 - 11:03 AM
diegohiga
Joined May 4, '09
From coral springs florida US
Hey people i have a question and try to look it up but didnt find the right answer.. i just ordered a set of megan racing coils and i know my camber will become very negative.
I know people use the camber bolt for the rear and install the camber bolt in the upper hole but my question is can you use the camber bolt in the upper hole and bottom hole too? To get more possitive camber using 2?
Next question can i use camber bolts in the front? If so is it really hard to install it correctly? And can i use 2 bolts in the same strut?
I would like to do this if my camber becomes too negative and cant fix it with one bolt per side because one bolt only moves -+1.75 and sometimes your camber even gets to -3 with coils depending how much you lower it.
Thanksssssss
This post has been edited by diegohiga: Aug 6, 2011 - 11:06 AM
Lo-Fi Version Time is now: August 30th, 2026 - 6:22 PM
