> rear convertible window off track
post Aug 8, 2011 - 8:41 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
wasn't sure where to put this but tonight after putting my top back up and my windows i heard a clunk and my window in the rear passenger side now wont go up on its own, it puts it slanted. I know its off track but does anyone know how to fix this?
Replies (1 - 6)
post Aug 8, 2011 - 9:09 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (freddy121389 @ Aug 8, 2011 - 9:41 PM) *
hmm, make sure the 'roller things' arent broken. that happened to mine, and i test drove a few verts and all of them had that. if im not wrong even d-mans vert had that broken.
well now to answer your question, if its not broken:
depending on how badly its off-track, u should be able to fix it by adjusting it from the side. take the rear panels off, put your arm around the right side, and try it from there.
i hope this helps.
post Aug 8, 2011 - 10:16 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
DMAN no longer owns the vert, but yes it has the same issue
post Aug 9, 2011 - 5:56 PM
so dman sold the vert. damn
post Aug 9, 2011 - 6:26 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (njccmd2002 @ Aug 9, 2011 - 6:56 PM) *
Yups... I almost bought it but took to Long to respond. frown.gif oh well
post Aug 24, 2011 - 9:59 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
your window might have slipped past the stoppers. Undo the 2 screws for the cover, than take a flash light and look at the end of the regulator tracks. There should be a small L shaped bracket (stopper) If your window looks like it just pop past it while going down, you can just undo the stopper, put up the window, guide the window back into the tracks and reinstall the stopper.
Hope that helps!
post Aug 28, 2011 - 9:09 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (vile_v @ Aug 24, 2011 - 10:59 PM) *
Hope that helps!
The whole track is bolted down by 1 nut attached to the frame of car if it is loose whole track could fall down. It is next to speaker bolt.
Lo-Fi Version Time is now: June 10th, 2026 - 4:47 AM
