Aug 10, 2011 - 2:15 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
my oil engine light came out whethever i puss the gas a little bit .... when im on gear and running, and goes away the second i leave the gas completly
if i put just a bit when accelerating , it will do it but sometimes flash. i dont lose and burn any oil my dipstick have correct oil in it, i did change oil and did put the excxat amount on it, so it dont need more oil why my oil light came out , ? This post has been edited by Needles: Aug 18, 2011 - 12:42 PM |
Needles oil pressure gauge Aug 10, 2011 - 2:15 PM
jordisonjr Low oil pressure? Aug 10, 2011 - 2:45 PM
6G96GT maybe your oil pump is on its way out? Perhaps you... Aug 10, 2011 - 3:18 PM
Needles QUOTE (6G96GT @ Aug 10, 2011 - 3:18 ... Aug 13, 2011 - 2:19 PM
SupraKid You should be running a oil pressure gauge, becaus... Aug 13, 2011 - 3:19 PM
Needles i have unbolt the bolt next to the original oil pr... Aug 14, 2011 - 3:15 PM
Needles no oil goes tru the tube i tee in the engine...
si... Aug 15, 2011 - 1:48 PM
stephen_lee i would use the same port as the stock pressure sw... Aug 16, 2011 - 9:23 AM
Needles its look that way, oil pump fail, im not sure but,... Aug 16, 2011 - 1:41 PM
stephen_lee DEATHs OEM oil pump (rather the oil pump pulley) f... Aug 16, 2011 - 4:37 PM
Needles i have succesfully install the oil plug into the o... Aug 18, 2011 - 12:04 PM
6G96GT QUOTE (Needles @ Aug 18, 2011 - 12:0... Aug 19, 2011 - 7:23 PM
Soulend Oil is cold at start up and so its thick causing h... Aug 18, 2011 - 3:25 PM
stephen_lee loooks like toyota wants >5psi at idle and 36-7... Aug 18, 2011 - 4:46 PM
Needles after installing the gauge, its seem its all good,... Aug 18, 2011 - 10:17 PM
Delta_Phoenix Low pressure = high flow = oil is hot and thin. OR... Aug 20, 2011 - 11:16 PM
Needles in fact , i worked all day whit my car , (3sgte 3t... Aug 21, 2011 - 12:43 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:34 AM |
