> Jdm headlight question,
post Aug 14, 2011 - 2:47 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
I just bought a set of the jdm headlights, low projectors and clear highs;
One question though, what bulb goes in the low beams and how do I hook it up?
post Aug 14, 2011 - 2:56 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
just high low for the connectors. if i remember correctly there is one color that is common to both connectors and the other is different, but dont quote me on that. and the bulb is an H1 bulb. it should also say it on the housing.
post Aug 14, 2011 - 3:30 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (ST205WRC @ Aug 14, 2011 - 2:56 AM) *
Yea by the looks of it, high beam are the same bombs,
The low is h1 axcording to "info" bit seller said it's h7
And how do I wire the low beam?
post Aug 14, 2011 - 6:31 AM
azian_advanced
Joined Apr 18, '05
From Calgary
the info is in the stickies
Projector Lights Install
post Aug 15, 2011 - 3:00 PM
chacha
Joined Dec 29, '05
From So-Cal
i did a sticky too for the side indicators...check it out
post Aug 17, 2011 - 4:36 PM
trdproven
Joined Aug 2, '05
From Guam
that sticky is obsolete. I created an adapter that is plug n play and no permanent damage, and fully reversible by removing the adapter. This is what I sent to another member, since I get some questions about how I did my adapter. I've been meaning to take a pic of it for a very long time. I will one day... for now here it is.
The way I did it was i got a heavy duty harness for a 9006 bulb, this end will attach to your stock harness. Then you get an H1 harness from an auto parts store, technically you can use an H4 connector which i did cus they didnt have an H1 connecter. THe h4 only difference is you don't use the 3rd terminal. I spliced the H1 harness with the 9006 harness (not the stock one, from the heavy duty one). You'll notice which parts to splice cus one is for the bulb and one is for your stock 9006 harness. I used a butt connector to secure it. After that I used wire loom to cover the wires and electrical tape the ends to make it OEM-ish. There you have it, an OEM stock looking adapter that doesn't cause any permanent cutting of your factory.
For the H1 bulb itself, you'll notice the bulb is somewhat loose meaning the HID bulb, so you use the HID plastic ring to make it tight. The H1 bulb and the HID H1 bulb is no difference besides you have to use that plastic spacer or anything you want to use and also instead the HID bulbs have wires instead of spades coming out directly from a regular bulb. Good luck
This post has been edited by trdproven: Aug 17, 2011 - 4:43 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: June 28th, 2026 - 2:49 PM
