Aug 14, 2011 - 9:21 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
My initial thoughts on this would be to make some clear (as to not detract significantly from the look of the car) body panels to improve aerodynamic efficiency... but I have a separate thread for that http://www.6gc.net/forums/index.php?showto...mp;#entry928769
I post here however to discuss engine mods. Any ideas or thoughts on this? I was thinking of maybe advancing the ignition timing a bit to burn hotter, increase hp and hopefully mpg, but idk. Does a good CAI help? or a larger O.D. exhaust? What have you guys done? -------------------- ![]() |
ricochet1490 What have we done to improve 5s mpg? Aug 14, 2011 - 9:21 PM
RabidTRD Anything that helps the car breathe better increas... Aug 14, 2011 - 9:27 PM
ricochet1490 QUOTE (RabidTRD @ Aug 14, 2011 - 10... Aug 14, 2011 - 9:38 PM
richee3 QUOTE (RabidTRD @ Aug 14, 2011 - 9:2... Aug 14, 2011 - 9:41 PM
stephen_lee the biggest increase in MPG comes from a lighter f... Aug 14, 2011 - 10:03 PM
Smaay Turbos do NOT increase MPG, in fact they hinder it Aug 15, 2011 - 1:10 PM
KAOS QUOTE (Smaay @ Aug 15, 2011 - 12:10 ... Aug 15, 2011 - 1:37 PM
bloodMoney Or you can do what Richee did and just swap in a B... Aug 15, 2011 - 1:12 PM
jordisonjr ^ No kidding.
And boost doesn't help the fact ... Aug 15, 2011 - 1:59 PM
ricochet1490 QUOTE (jordisonjr @ Aug 15, 2011 - 1... Aug 15, 2011 - 4:31 PM
azian_advanced in terms of exhaust diameters for ideal flow, this... Aug 15, 2011 - 7:34 PM
ricochet1490 QUOTE (azian_advanced @ Aug 15, 2011 - 7... Aug 15, 2011 - 7:51 PM
azian_advanced it would reduce hp actually but not by much. whil... Aug 15, 2011 - 9:38 PM
ricochet1490 i could envision that after a certain point, press... Aug 15, 2011 - 10:05 PM
azian_advanced advanced timing will gain hp at higher revs so thi... Aug 15, 2011 - 11:01 PM
stephen_lee smaller static displacement = less air/fuel req... Aug 16, 2011 - 9:18 AM
spolski07 lightweight flywheel will remove a lot of the rota... Aug 16, 2011 - 11:56 AM
stephen_lee QUOTE (spolski07 @ Aug 16, 2011 - 11... Aug 16, 2011 - 12:59 PM
ricochet1490 QUOTE (stephen_lee @ Aug 16, 2011 - 12... Aug 16, 2011 - 5:24 PM
jlspec Ok finally did some testing of MPG for my 99 vert.... Sep 7, 2011 - 4:19 PM
ricochet1490 I have never seen 35 under any circumstances, but ... Sep 7, 2011 - 5:23 PM
jlspec Yeah, the first trip I took gave me 35 mpg which I... Sep 7, 2011 - 7:53 PM
ricochet1490 QUOTE (jlspec @ Sep 7, 2011 - 7:53 P... Sep 7, 2011 - 9:30 PM
CaliJeff Basic stuff to help is what you would do for a tun... Sep 16, 2011 - 7:56 PM
kamax QUOTE (CaliJeff @ Sep 16, 2011 - 6:5... Sep 21, 2011 - 3:52 AM
bloodMoney ^ This.
I put 1200 miles on the car this past we... Sep 20, 2011 - 9:10 PM
ricochet1490 QUOTE (bloodMoney @ Sep 20, 2011 - 10... Sep 20, 2011 - 9:57 PM
richee3 QUOTE (bloodMoney @ Sep 20, 2011 - 9... Sep 22, 2011 - 4:35 PM
bloodMoney Yea its a MT. Sep 22, 2011 - 4:20 PM
bloodMoney Yup Yup.
You know I'd take it in a heartbeat,... Sep 22, 2011 - 8:29 PM
NYp8tBaller07 keep it as stock as you can and try to reduce some... Sep 22, 2011 - 10:03 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 5:08 PM |
