Aug 16, 2011 - 12:07 PM
Enthusiast ![]() ![]() Joined Nov 13, '08 From San Antonio, Tx Currently Offline Reputation: 8 (100%) |
my car has been stuttering on idle after start up and at stop lights and wondering why since i have new dizzy, wires, plugs, fuel filter and pump. could it be my timing?
is the firing order 1-3-4-2? been searching all morning and looking through multiple pages but can't seem to find. Thanks for any help or links. another topic is i have an oil leak, went to the mechanic at the corner and we took a look and told me it was my o-ring on dizzy, so i took the dizzy off and the oring is still in tact. is there a gasket that goes before the dizzy because i do have a small gap between dizzy and head. This post has been edited by marco-polo: Aug 16, 2011 - 12:33 PM |
marco-polo Spark firing order? Aug 16, 2011 - 12:07 PM
stephen_lee replace the oring, it can leak even if its intact.... Aug 16, 2011 - 12:38 PM
marco-polo how do you know if injectors are plugged incorrect... Aug 16, 2011 - 3:17 PM
stephen_lee QUOTE (marco-polo @ Aug 16, 2011 - ... Aug 16, 2011 - 4:31 PM
lagos Why do you need to know the firing order? Aug 16, 2011 - 3:29 PM
marco-polo QUOTE (lagos @ Aug 16, 2011 - 3:29 P... Aug 16, 2011 - 8:43 PM
lagos QUOTE another topic is i have an oil leak, went to... Aug 16, 2011 - 3:32 PM
stephen_lee does it revv up fine? Aug 16, 2011 - 8:49 PM
marco-polo as of now the car barely turns on. Aug 16, 2011 - 9:22 PM
lagos QUOTE (marco-polo @ Aug 16, 2011 - ... Aug 16, 2011 - 9:57 PM
marco-polo QUOTE (lagos @ Aug 16, 2011 - 9:57 P... Aug 17, 2011 - 9:00 AM
xrav22 QUOTE (marco-polo @ Aug 17, 2011 - ... Aug 17, 2011 - 9:55 AM
Bitter a bad coolant temp sensor can screw with things to... Aug 16, 2011 - 10:30 PM
ST205WRC they do match up to the firing order. as stated ab... Aug 17, 2011 - 10:21 AM
match220 Also check your spark gap if your plugs are old. Y... Aug 18, 2011 - 3:32 AM
marco-polo QUOTE (match220 @ Aug 18, 2011 - 3:3... Aug 18, 2011 - 8:34 AM
lagos QUOTE (marco-polo @ Aug 17, 2011 - ... Aug 18, 2011 - 1:17 PM
marco-polo ^^ thanks Lagos helped me out! Aug 18, 2011 - 1:34 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 1st, 2026 - 11:18 AM |
