> Wideband to ECU st205
post Aug 18, 2011 - 6:42 AM
Neon90424
Joined Jan 19, '11
I need some help here guys I have an AEM UEGO wideband sensor and I cant figure out how to wire it to my ECU, its got 3 cables, Brown differenciated grd, white 0-1v narrowband signal and a 0-5v signal.
for some reason my wideband gauge only reads the 0-1v and it goes up and down when I use the launch control and revs it goes rich, and I tried on all 4 wires that go to the ECU and since the o2 sensor has been removed my car was idleing at 1200rpm kinda... and no changes at all in the idleing...
Yes the UEGO has power and is grounded directly to the battery...
post Aug 18, 2011 - 9:13 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if you have the same controller as me
red: b+ in diag box
black: e in diag box
white: hook to the stock primary O2 sensor wire
set your controller to P4 using the flat screw set in the back and watch the read out (changes P1, P2, P3, P4)
post Aug 18, 2011 - 12:17 PM
Neon90424
Joined Jan 19, '11
red and black ur tellin me is pos and neg, I dont find anything that can be moved with a screw driver on mine
what about brown and orange?
post Aug 18, 2011 - 4:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
post a pic of the back of your controller. it might be different than mine. at anyrate if u know the p/n or have the manual look in it to see what wire is the analog out and how to set it to emulate a narrowband
post Aug 18, 2011 - 5:50 PM
Neon90424
Joined Jan 19, '11
I have the emulated narrow band, my Wideband GAUGE for some reason wont understand 0-5v only the narrowband... and everytime I let off the throttle the gauge dips to lean and bleeps and is starting to piss mee offf!!!!
Lo-Fi Version Time is now: June 23rd, 2026 - 5:49 AM
