Aug 20, 2011 - 7:05 PM
Enthusiast Joined Sep 14, '09 From Michigan Currently Offline Reputation: 0 (0%) |
I currently have a 1994 Toyota Celica GT Coupe with a T3/T4 Turbo setup on it. Recently I noticed that coolant was leaking only after the car is shut off. After the car has been sitting for awhile, such as overnight, when I start it it blows a cloud of white smoke then runs normally after that. It does have an oil cooler, not sure if that's the problem though. The coolant overflow tank has also been removed. I was told it could be a lot of things. . Any advise would be awesome! Thanks, -Zach |
zwithey Coolant Leak! Help Please Aug 20, 2011 - 7:05 PM
xrav22 You should start by getting an overflow tank from ... Aug 20, 2011 - 9:21 PM
zwithey Thanks for the input. I'll give it a shot. Aug 21, 2011 - 8:04 AM
Bitter is the turbo water cooled? Aug 21, 2011 - 8:34 AM
zwithey It's oil and water cooled I believe. . . Aug 21, 2011 - 11:15 AM
Bitter are your spark plugs totally white and clean? Aug 21, 2011 - 1:21 PM
zwithey All the spark plugs but one look normal. One of th... Aug 22, 2011 - 10:41 AM
xrav22 QUOTE (zwithey @ Aug 22, 2011 - 10:4... Aug 22, 2011 - 10:59 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 6:25 PM |
