Aug 25, 2011 - 3:29 PM
![]() Enthusiast ![]() ![]() Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
The Celi finally left me stranded after 10 years of me driving it and putting 160k on it (275k total). Basic rundown:
Died... (OBD1 7AFE, btw) Checked for spark + fuel. No spark. Tested ignition coil w/ multimeter, out of spec. Replaced entire distributor after not finding a way to test the ICM ($265 @ Autozone). New dizzy was $130, pricematched to Rockauto.com, and included an ICM and ignition coil. Alive again, but missing horribly at idle and when cruising. Runs like a beast at WOT. Black smoke from exhaust, using TONS of fuel. Replaced plugs, wires, cap, and ign. rotor. Didn't help, same crap. Checked timing w/ timing light. It's perfect. 10 deg. BTDC. Ordered another dizzy from Autozone (of course they're all remanufactured), putting that on after work today to see what happens. Anyone have any other suggestions? Friends have suggested a compression test, but losing a cylinder AND a dizzy @ the same time? Not likely. That, and it's still pulling like normal at WOT, which isn't going to happen with a dead cylinder. Plus, I don't have access to a compression tester and I'm not buying one to use once. ECM a possibility? The ECM is still advancing the timing when TE1 and E1 are jumpered, so I know it's still got at least some level of intelligence left. I'm at a loss. |
Delta_Phoenix Misses when idling/cruising, pulls hard at WOT Aug 25, 2011 - 3:29 PM
jordisonjr I have no suggesetions but Good luck is all I can ... Aug 25, 2011 - 4:15 PM
stephen_lee try your O2 sensor. are you getting any CELs? unpl... Aug 25, 2011 - 6:38 PM
Bitter Does this car have EGR? Aug 25, 2011 - 8:11 PM
PolliS_5S-FE have a look at the ecu. mine went recently, 5s tho... Aug 27, 2011 - 4:47 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 9:46 PM |
