Aug 25, 2011 - 7:42 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Well my car was running pretty ****ty today, so I tried spraying some carb cleaner in through the intake (I recently changed the plugs, wires,cap and rotor so I knew it wasn't that.) and the car tried to die out liek it should. So I gave it some gas while spraying the carb cleaner and then when i stopped it idle'd normal.
Then out of nowhere the car jumped to like 5500RPM, or something rediculously high, so I ran and shut the car off, unhooked the battery and let it sit for about an hour. The car now consistantly idles at 3000rpm, and when i turn the ignition off to shut the engine off, it doesn't seems to shut off properly, but almost stalls itself out. Did I screw a lot of sh!t up? I guess you can't trust everything you read on these forums cause i've read it multiple posts that you can spray carb cleaner through the intake.. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 25, 2011 - 8:12 PM
tell exactly what you did.
Aug 25, 2011 - 8:28 PM
Started the car, sprayed the carb cleaner in and the car died, exactly as I expected.
Started it up, revved it up a bit and sprayed the cleaner in. stop spraying and stopped reving, the car idle'd normal for a few seconds, then it jumped up really high, almost redline. Disconnected the battery, let it sit there while i ate supper, went back out and it wa at 3 k. let it sit for say another hour, and it reved to 3k again. Drove the car around the bay, at 3k idle, and ii basically hit 40km/w without touching the gas pedal Went back out after about 2 hours, didn't start it yet, jiggled the throttle cable to see if maybe it was stuck, which it wasn't. So I just tried starting it, and it started up, revve to 2k, and now its idling normally again.. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 25, 2011 - 8:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
First problem. You used carb cleaner. It's too hot of a liquid. You probably destroyed your MAF or another sensor inside. I'd never run it while cleaning simply because you can suck the cleaner where you don't want it to go. Barrymans B12 Chemtool is the best throttle body cleaner I know of that won't kill your MAF or any sensor inside if it gets on it. Just don't run the engine. My guess is that it either damaged the MAF or another vacuum sensor inside when it got sucked into the vac lines.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Aug 25, 2011 - 8:57 PM
Enthusiast ![]() ![]() Joined Dec 30, '09 From Wilmington, NC Currently Offline Reputation: 1 (100%) |
First problem. You used carb cleaner. It's too hot of a liquid. You probably destroyed your MAF or another sensor inside. I'd never run it while cleaning simply because you can suck the cleaner where you don't want it to go. Barrymans B12 Chemtool is the best throttle body cleaner I know of that won't kill your MAF or any sensor inside if it gets on it. Just don't run the engine. My guess is that it either damaged the MAF or another vacuum sensor inside when it got sucked into the vac lines. Was pretty sure 5s didnt have a MAF, just MAP and IAT like the 7a...could be wrong though. |
Aug 25, 2011 - 9:46 PM
Started the car, sprayed the carb cleaner in and the car died, exactly as I expected. Started it up, revved it up a bit and sprayed the cleaner in. stop spraying and stopped reving, the car idle'd normal for a few seconds, then it jumped up really high, almost redline. Disconnected the battery, let it sit there while i ate supper, went back out and it wa at 3 k. let it sit for say another hour, and it reved to 3k again. Drove the car around the bay, at 3k idle, and ii basically hit 40km/w without touching the gas pedal Went back out after about 2 hours, didn't start it yet, jiggled the throttle cable to see if maybe it was stuck, which it wasn't. So I just tried starting it, and it started up, revve to 2k, and now its idling normally again.. sprayed where? -------------------- |
Aug 25, 2011 - 9:55 PM
First problem. You used carb cleaner. It's too hot of a liquid. You probably destroyed your MAF or another sensor inside. I'd never run it while cleaning simply because you can suck the cleaner where you don't want it to go. Barrymans B12 Chemtool is the best throttle body cleaner I know of that won't kill your MAF or any sensor inside if it gets on it. Just don't run the engine. My guess is that it either damaged the MAF or another vacuum sensor inside when it got sucked into the vac lines. Was pretty sure 5s didnt have a MAF, just MAP and IAT like the 7a...could be wrong though. Yeah, I'm not 100% myself. I thought it was on the back, bottom of the throttle body like on my camry, but now I don't remember seeing one. Regardless, it can still screw up the other sensors I it gets sucked into the vacuum lines. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Aug 25, 2011 - 9:58 PM
I sprayed it through the short ram intake.
I started it before I got any responses to this thread, and it idled normal again. Should I be okay to run it like this? I've sprayed it through another time, and it didn't cause any issues. And I thought that the 5sfe didn't have a MAF either. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 25, 2011 - 11:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
check that your butterfly valve isn't getting stuck...it can get stuck without the throttle cable
Aug 25, 2011 - 11:47 PM
The Celica's 5S is definitely MAP and IAT, not MAF.
There's a separate kind of cleaner for the TB, that's what I prefer to use. I assume there's a difference in the chemicals, though I don't know what it is. The directions on the back of the bottle for my TB cleaner say spray it directly in the throttle body while working the butterfly valve back and forth by hand with the motor off. It also says don't continuously spray- only do short blasts. I've noticed the stuff evaporates pretty quickly if there isn't too much of it, so maybe that had something to do with it. If the car is fine now, I'd say lesson learned, no real harm done. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 26, 2011 - 2:01 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Did you read the instuctions on the cleaner??
The throttle body cleaner I have says not to spray when the engine is running. -------------------- God made man....
Everything else... Made in China ![]() |
Aug 26, 2011 - 10:05 AM
Richee3: Thanks that gives me some sort of relief haha.
Nics: I did read the instruction, but since this was carb cleaner, not throttle body cleaner it was a little different. But it did say that it was safe to spray on your carb, while running, just turn the idle up. I figure that would be the same thing as making the car idle higher by opening the throttle up a bit. But the car is idling normal now, so I guess its alright.. Not doing that again though. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 26, 2011 - 2:30 PM
![]() Enthusiast ![]() Joined Aug 1, '11 From San Diego, CA Currently Offline Reputation: 0 (0%) |
It was just the butteryfly that was stuck. The carb cleaner must of remove all grease and such from the butterfly joints which caused it to be stuck open. After you drove it around a bit it must of regrease it through the oil vapor from your valve cover. Just remeber the only way for a engine to rev so high is a open throttle. Every sensor around your engine can break and it will never rev that high. No air, no spark, no rev.
-------------------- ![]() 1990 Celica Turbo All-Trac, 1977 Celica GT Liftback, 1999 Celica GT Convertible, 2004 Lexus IS300 5-Speed |
Aug 26, 2011 - 2:42 PM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
I was thinking of doing this too so let me get this straight:
1. Remove intake (car switched off) 2. Spray throttle body cleaner inside while playing the the throttle so it gets inside 3. Put everything back in 4. Start car. Is that right? -------------------- For Sale:OEM tail lights - make offer
Aug 26, 2011 - 7:37 PM
This happened to me as well but it was idling @2k rpms. I disconnected the battery terminal as well. It could be the ECU itself, trying to reset itself or something.
| Lo-Fi Version | Time is now: August 23rd, 2026 - 11:01 PM |
