> HID fog lamps, has anyone tried this yet?
post Aug 29, 2011 - 5:41 PM
199celica
Joined Jul 29, '11
From chino, Ca
im working on making a housing that will cover the back of the fog lamps since it is so low to the ground i want the lights to be functional yet durable in the rain and on rocky roads such as construction sights. any ideas will b help im open to all comments. thanks guys
post Aug 29, 2011 - 8:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i have autozone projector fogs w/ an hid kit. works nice && when mounted properly will last a good while.
post Aug 29, 2011 - 9:00 PM
199celica
Joined Jul 29, '11
From chino, Ca
QUOTE (stephen_lee @ Aug 29, 2011 - 8:50 PM) *
Yeah ive seen that done before (not to b a jerk jus saying) but i want to b different i want the original fog lamps to b hid i havnt seen anyone do it yet
post Aug 29, 2011 - 9:07 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
it should be the same as converting your headlights to HID
post Aug 29, 2011 - 11:02 PM
199celica
Joined Jul 29, '11
From chino, Ca
I thought it would b the same to but the fog lamp bulb is held in by what looks like a battery and a bulb with a white rope looking wire and spring its definetely different, i havnt seen this before haha
post Aug 30, 2011 - 12:58 AM
CrimsonSTX
Joined Jun 9, '07
From Miami, FL
QUOTE (199celica @ Aug 30, 2011 - 12:02 AM) *
That's the H3 Halogen Bulb.
post Aug 30, 2011 - 6:50 AM
199celica
Joined Jul 29, '11
From chino, Ca
QUOTE (CrimsonSTX @ Aug 30, 2011 - 12:58 AM) *
Ok kewl ill have to borrow a set of my buddies then haha i kno im a newb bare with me please haha
post Aug 30, 2011 - 8:50 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its a little different to mount the bulb but with reasoning you can do it smile.gif
post Aug 30, 2011 - 9:57 AM
richee3
Joined Jun 29, '08
From Denver
I was just looking at a set of HID fogs on a Celica this weekend. It looks like what you have to do is cut a hole in the back of the housing for the wires then seal it up with some silicone.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 30, 2011 - 11:52 AM
199celica
Joined Jul 29, '11
From chino, Ca
Ok ill look into that
post Aug 30, 2011 - 12:57 PM
zonz540
Joined Jul 3, '09
From UT
I have them, its just a replacement bulb wired through the HID ballast. You have to run wires and seal with silicone or rtv. Pretty easy and it matches the low-beams.
post Aug 30, 2011 - 3:20 PM
199celica
Joined Jul 29, '11
From chino, Ca
no way i have never seen it done on our 6gc's man is there any way u can send a link where you got them or direct me where i can get them?
post Aug 30, 2011 - 6:00 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
QUOTE (richee3 @ Aug 30, 2011 - 10:57 AM) *
I've done it. The only downside to this is that if the bulbs go out, I'll need to pull off all the sealant and lay down a fresh patch.
Basically, I drilled a hole in the housing where the OEM cable came through. The hole was just barely big enough to get the HID connectors through, then I plugged it all back up with some RTV. I've had them on since December and haven't had a problem with them.
~bloodMoney
post Aug 30, 2011 - 7:28 PM
trdproven
Joined Aug 2, '05
From Guam
I have full HIDs installed into my fogs and low beams, everything else on my car is LED converted. Heres a crappy pic below.
This post has been edited by trdproven: Aug 30, 2011 - 7:32 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 31, 2011 - 3:00 PM
199celica
Joined Jul 29, '11
From chino, Ca
Dam that looks sick see thats what i want man what did u do?
Lo-Fi Version Time is now: August 22nd, 2026 - 7:56 PM
