> Strange noise coming from 94' GT
post Aug 30, 2011 - 5:28 PM
GearHead899
Joined Feb 13, '11
From Ocean View, NJ
Theirs a new strange noise coming from my girls Celica. I just put on new tenzo R springs today and KYB shocks and it looks and feels great. but now it looks like ill have a new project soon. she says its been doing it for a little while so its nothing caused by the new suspension. Its kind of a grinding noise but doest sound like metal on metal or anything. almost sounds like a bad bearing. Coming from the front end. It mostly does it when your turning right and going from a stop, it continues as you accelerate but sounds like it may quiet up a bit once you go over 45mph, but it could just be the wind noise that causes me not to hear it anymore. And when i put the clutch in the sound stops. So i was thinking maybe throw out bearing? but hears the weird part... going from a stop while making a right you hear it pretty loud, but if you go from a stop when your turning left you dont hear it at all. Any ideas guys??
My Car - BPU 92' 3000GT VR4
Her Car - 94' Celica GT (project car)
post Aug 30, 2011 - 5:38 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
left side wheel bearing. should do the same around harder curves, too.
post Aug 30, 2011 - 5:41 PM
GearHead899
Joined Feb 13, '11
From Ocean View, NJ
i was kinda thinking that but could it still be that if it goes away when the clutch is pressed in? and is their a way to test it without just replacing it?
post Aug 31, 2011 - 9:03 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
does it happen when you are stopped? i had a bad throwout bearing and it made the noise even when the car wasnt moving.
post Aug 31, 2011 - 3:07 PM
GearHead899
Joined Feb 13, '11
From Ocean View, NJ
well i figured it out. it is a bad wheel bearing... but on the passenger side! its so weird that the noise happens when you turn right and the weight should be off it, but w/e. i jacked it up and the passenger side front wheel had alllll types of play. so im getting a new wheel bearing tomorrow, it sucks they have to be pressed in so i cant do it myself, so im dropping it off at my buddies shop and gonna have him do it. ill let you guys know how it turns out!
Lo-Fi Version Time is now: May 16th, 2026 - 1:59 PM
