> 18x9,5 ET 25 front / 18x10 ET 12 back, Will it fit?
post Sep 2, 2011 - 10:01 PM
Ehrgeiz
Joined May 23, '11
From The Netherlands
Hey guys, as the topic title describes; 18x9,5 +25 in the front, 18x10 +12 in the back (with 215/35 front tires, 225/35 rear tires).
Will this fit? Or does it need too much modification? It's a '94 n/a and will have coilovers in the future aswell.
Thanks!
post Sep 2, 2011 - 10:29 PM
LimitedGT4
Joined Apr 18, '11
From Southern Alabama
look in my profile similar size wheels and look great
post Sep 3, 2011 - 8:53 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
QUOTE (LimitedGT4 @ Sep 2, 2011 - 8:29 PM) *
Good job on misleading the OP. What ARE your wheel specs? They're nowhere near what he's trying to do, so stop with the bad info.
OP - those wheels will definitely not fit. Here is a link to the flush fitment thread. Everything you need is documented there.
http://www.6gc.net/forums/index.php?showto...t=0&start=0
**** Photobucket
post Sep 3, 2011 - 9:04 AM
LimitedGT4
Joined Apr 18, '11
I guess u dnt know how to read keyword SIMILAR and they are 18x 8.5 front and 9.5 back SIMILAR read before u say things that make no sense missleading no i dnt let suggestions tell me what can and cant be done
post Sep 3, 2011 - 9:38 AM
95CelicaST
Joined Feb 5, '05
OFFSET. Width means nothing. What OFFSET do you have. That is what its important when fitting wheels. Had you known you probably wouldn't have posted, because you would know a 18x10 +12 would not even come close to fitting the rear.
**** Photobucket
post Sep 3, 2011 - 11:26 AM
Ehrgeiz
Joined May 23, '11
Thanks alot guys, the flush wheel fitment topic is everything I need. smile.gif
I'm trying to go for a bit of a Hellaflush treatment, so I want the wheels to stick out a bit and stretch the tires. I'll try and look into the perfect size for that.
Thanks again!
Lo-Fi Version Time is now: June 12th, 2026 - 6:32 AM
