2 Pages V  < 1 2
> spark plug wire issue, How/why did this happen rite after replacing the wire?
post Sep 16, 2011 - 1:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i saw a rattling like youe old engine did.. turned out to be loose flywheel bolts.
did you use thread locker on your fly bolts? torque them properly?
post Sep 16, 2011 - 1:54 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (stephen_lee @ Sep 16, 2011 - 2:26 PM) *
This is strange sounding I was just wondering did you hear a snap when you put the wires into the distributor because they have to lock.
And I had a hard time getting my wires all the way down because they also pop when they go down all the way.
Other than that nothing could change unless you put a hand on and lean on the distributor and if it was loose you could have moved it down.
post Sep 16, 2011 - 7:55 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
old wires were core so they're gone.
anyways, today this guy checked it out, and here are the problem(s):
timing belt was loose and hitting something under the cover so it was damaged and if i kept driving it, eventually snapped.
noise wasnt 'loud' enough to be bearings, "definitively timing."
other stuff was also found wrong:
cable bad, motor mounts,bolts missing here and there.
so now for 250 plus parts, im getting all that fixed. hopefully done rite this time.
the only thing i cant understand why the noise started coming after the wire replacement.
is it a coincidence or they're related?
post Sep 16, 2011 - 8:10 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
coincidence
post Sep 17, 2011 - 8:54 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
strange, but coincidence. Looks like God saved u:)
post Sep 21, 2011 - 7:46 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Nevermind; I was driving it to the mechanics place and about half way there
The knocking noise got louder, and continuous; pulled over, recognized that noise, it was the bearing (again). Was getting off the freeway and then:
BAAM! Big bang; smoke everywhere
Rod out of block, hole in block
Time for rebuilding my old engine.
post Sep 21, 2011 - 8:11 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Also the mechanic looked at my old engine, said the bearing weren't that bad so all he's gonna do is put new bearings in and done.
Is that fine, like don't u have to machine the block and crank? Or is that only if it'd really bad?
The old engine was definatelly not as bad as this once, there was no smoke or anything, just knocking noise.
According to him: "when I spinned the crank, the pistons still had compression in them so that means the walls and pistons are fine"
Is he rite?
post Sep 22, 2011 - 12:33 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Damn! that bearing again? get good ones next time... acl wouldnt b bad. Well, the bearing alone can b changed. anyway when he opens the engine he will b able to confirm wether the pistons or rods r gone too. ul probably need a new headgasket aswell...hks makes good ones.
post Sep 22, 2011 - 12:53 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (Rav4Race @ Sep 22, 2011 - 1:33 AM) *
Well this current motor was out of a junk yard with unknown miles,
And the previous stock one (which is going back in the car soon) had eBay ones, which is probably why they went bad.
The mechanic looked at it and said that "I could feel it, the pistons still had compression in them" when he was turning the crank. And apparently only one bearing was loose.
It was still in And somewhat technically installed.
The references this mechanic gave this time were
Stephen_lee, DEATH, D-man.
If any one u guys read this can u cofirm that this time the mechanic REALLY knows what hes doing?
I don't mean to sound like a dick but u all know, I got screwed over from the past 3 previous mech. And it's just more of a concern now rathe than judging the other persons capability, I don't mean ANYTHING negative by it.
The guys name is joon/junior.
post Sep 22, 2011 - 8:31 AM
mkernz22
Joined May 10, '10
From MA
Why don't you try rebuilding it yourself? Just buy an engine stand from harbor freight for $40 and do it in your garage. You have all the information you need to do it on here. I'm only 18 and I rebuilt the front end of my car in my driveway and I also did a full auto to manual swap in my driveway as well as remove all my ABS crap and put in non ABS. If you have the time, try doing it yourself, but if you don't have the time, then that's completely understandable.
post Sep 22, 2011 - 3:15 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Joon knows his ****
post Sep 22, 2011 - 5:43 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (stephen_lee @ Sep 22, 2011 - 3:15 PM) *
Joon knows his ****
So I got the right mechanic this time? Rite?
Nothin to worry abt? It's gonna be done rite this time?
And mkernz22:
I know, but the problem I have is
1. I lack confidence in my capabilities when it comes to my own car, every other car, I can do anything lol
2. My neighborhood doesnt like me working on my car and everytime they see me with a tool outside I ge letters and sh**
3. I need it done fast, can't afford to take my time.
But yea eventually Ill grow over my fear and finally doing my own work on my car. Eventually.
post Sep 23, 2011 - 8:58 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
He'll hook you up proper. I've worked with the guy before.
2 Pages V  < 1 2
Lo-Fi Version Time is now: May 27th, 2026 - 2:43 PM
