Sep 14, 2011 - 5:25 PM
Enthusiast ![]() ![]() ![]() Joined Jun 5, '06 From Hayward,CA Currently Offline Reputation: 4 (100%) |
Hi folks. I have a 1999 hatchback GT thats starting to show some symptons of engine problems.
It has 108,000 miles, and just had a major tune up at around 106,000. The problem is, maybe like 2-3 times a week, as soon as I turn the ignition, the car will fire right up, and almost immediately the RPM will drop to 0 and the engine will die. Sometimes it doesnt die right away, but the engine will struggle and the RPM will continue to drop to 0 and the engine will die anyways. This will happen over and over again unless I press down on the gas a little to keep the RPM up. After holding down the gas for maybe 20 seconds, I can let go and the car will idle fine and its all good from there. Also, alot of times, the idle will be very very low. like around 400-500 rpm. I can feel the engine vibrating the entire car. After driving around for a little the idle will return back to around 1000 and everything will be fine. But sometimes if I press the gas too much too soon, the RPM will once again reach 0 and the engine will die. any ideas what kinda problems I could be having? I would be very thankful for any kind of insight. |
Sep 14, 2011 - 5:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
IAC, TPS, vaccum leak, Distrib coil failing, bad gas in tank??, fuel filter, fuel pump not giving enough, fuel press reg.
on the home page of this section in the stickies theres a thread to a pdf i think that tells you how to test the distrib coil with a multimeter to check for ohms hot and cold I would clean the throttle body first, check vac lines, inspect IAC and TPS -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Sep 14, 2011 - 6:17 PM
yea sounds like an IAC
Sep 16, 2011 - 1:08 AM
Enthusiast ![]() Joined Jul 14, '08 From Mauritius Currently Offline Reputation: 0 (0%) |
u said u had a major tune up?...what u mean by major tune up? i think its just a problem with your cold start, specially if u had a 'major tune up'. Or simply fine tune the idle, by stretching ur accelerator cable. sorry i don't know the exact english term for the 'stretching accelerator cable'
Sep 23, 2011 - 1:03 PM
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:21 AM |
