Sep 16, 2011 - 12:09 AM
Enthusiast ![]() ![]() Joined Mar 4, '10 From Bronx NY Currently Offline Reputation: 3 (100%) |
Has anyone on this forum done the 4th gen 3sgte swap ???? i have a few questions into where somethings are suppose to go such as some vacuum lines also the fuel line coming back from the pressure valve
please help just post here or hit me with a PM thanks -------------------- Always fast and going for the look......
Sep 21, 2011 - 10:23 PM
Enthusiast ![]() Joined Sep 23, '08 From riverside, ca 909 Currently Offline Reputation: 2 (100%) |
post pics... i can help
-------------------- ![]() I <3 MY ST214 |
Sep 21, 2011 - 11:13 PM
oh kewl i think i figured out the vacuum part just not the charcoal portion ...I wanted to know where does the tubing for the goes directly ??? cause on the caldina scamatics it shows it going to a tvv then from that to nowhere lol... also theres on vacume line port on the throttle body just one , its usaully where the egr stuff on the 5SFE engine goes but i noticed on the 4th gen 3SGTE there is no map;egr;or etc... please help
I will try to post pics tomorrow after work thanks post pics... i can help
Sep 22, 2011 - 1:17 AM
to my knowledge, there is a vsv for the charcoal canister. its a evap vsv if im correct. the vacuum portion runs from charcoal canister to vsv to throttle body. there should be a nipple on the throttle body and that is where the purge is fed. there is a map sensor on the 4th gen. the turbo pressure sensor is the map sensor. 4th gens dont have egr as it was never smog legal in the US
Sep 22, 2011 - 12:16 PM
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
the 4th gen, do no use EGR, but devinetly a map sensor here a link which can help http://www.toyodiy.com/parts/g_J_1998_TOYO...215W-DWMZZ.html here you can see the MAP sensor -> 89412-21010 http://www.toyodiy.com/parts/p_J_1998_TOYO...MZZ_8404.3.html greetz -------------------- |
Sep 22, 2011 - 10:32 PM
OK but i do not have the vsv ...didnt come with the engine ,,, is there another way to route this tube straight to the throttle or is there another vsv type part from the old engine i can use???
Sep 22, 2011 - 11:27 PM
Also here is a question... I dont have a hard line for the master cylinder I installed for the clutch.. whats can i safely use to run from there to the slave on the transmission ????
Sep 23, 2011 - 1:33 AM
Enthusiast ![]() ![]() Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
Has anyone on this forum done the 4th gen 3sgte swap ???? i have a few questions into where somethings are suppose to go such as some vacuum lines also the fuel line coming back from the pressure valve please help just post here or hit me with a PM thanks yep i have it in my car |
Sep 23, 2011 - 2:11 AM
yep you have what in your car ?? if u meant the 4thgen then please till me my last two treads
Has anyone on this forum done the 4th gen 3sgte swap ???? i have a few questions into where somethings are suppose to go such as some vacuum lines also the fuel line coming back from the pressure valve please help just post here or hit me with a PM thanks yep i have it in my car -------------------- Always fast and going for the look......
Sep 23, 2011 - 3:06 AM
yep you have what in your car ?? if u meant the 4thgen then please till me my last two treads Has anyone on this forum done the 4th gen 3sgte swap ???? i have a few questions into where somethings are suppose to go such as some vacuum lines also the fuel line coming back from the pressure valve please help just post here or hit me with a PM thanks yep i have it in my car a 4th gen Also here is a question... I dont have a hard line for the master cylinder I installed for the clutch.. whats can i safely use to run from there to the slave on the transmission ???? the line for the slave cylinder should be on the car already if u had a s54 aka 2.2 5sfe transmission.even if u had a 1.8 7afe its the same line. if u dont have one u need to get to the junk yard and get one or napa will make u one oh kewl i think i figured out the vacuum part just not the charcoal portion ...I wanted to know where does the tubing for the goes directly ??? cause on the caldina scamatics it shows it going to a tvv then from that to nowhere lol... also theres on vacume line port on the throttle body just one , its usaully where the egr stuff on the 5SFE engine goes but i noticed on the 4th gen 3SGTE there is no map;egr;or etc... please help I will try to post pics tomorrow after work thanks post pics... i can help the 4th gen does have a map sensor those lines on the throttle body i just put a plug on them OK but i do not have the vsv ...didnt come with the engine ,,, is there another way to route this tube straight to the throttle or is there another vsv type part from the old engine i can use??? to my knowledge, there is a vsv for the charcoal canister. its a evap vsv if im correct. the vacuum portion runs from charcoal canister to vsv to throttle body. there should be a nipple on the throttle body and that is where the purge is fed. there is a map sensor on the 4th gen. the turbo pressure sensor is the map sensor. 4th gens dont have egr as it was never smog legal in the US vsv u should have the old one that was on the car just use it
| Lo-Fi Version | Time is now: September 2nd, 2026 - 4:20 AM |
