Sep 19, 2011 - 10:20 PM
Enthusiast Joined Jun 24, '10 From NC Currently Offline Reputation: 0 (0%) |
I got a 1998 celica gt 2.2 and I need to know what I would need to convert to a v6 turbo. What engine should I use and what do I need to convert
xSoulReaper1018 98 celica v6 turbo conversion Sep 19, 2011 - 10:20 PM
Keiri Welcome to the board Soul and good to see you... Sep 20, 2011 - 8:08 AM
xSoulReaper1018 Thanks man. I'm in Wilson Sep 20, 2011 - 12:33 PM
95CelicaST QUOTE (xSoulReaper1018 @ Sep 19, 2011 - ... Sep 20, 2011 - 1:09 PM
JesiCanon - Use a E153 transmission. Again, same as above. D... Sep 27, 2011 - 4:41 AM
nics QUOTE (JesiCanon @ Sep 27, 2011 - 2... Sep 27, 2011 - 6:29 AM
OOBE LOL. Sep 27, 2011 - 7:12 AM
stephen_lee as stated
search. read. learn. fix current issues... Sep 27, 2011 - 9:27 AM
Smaay ok ill bite, just for information purposes on this... Sep 28, 2011 - 9:13 AM
95CelicaST Iron holds up to the abuse of Forced Induction. Th... Sep 28, 2011 - 12:48 PM
Smaay you are correct that an iron block will hold up be... Sep 28, 2011 - 4:15 PM
95CelicaST I agree the 1MZ is a better motor (I am a bit bias... Sep 29, 2011 - 9:46 AM
Neon90424 3vz is a 2jz disguised as a twin bank engine Sep 29, 2011 - 10:55 AM
95CelicaST No it's not. Sep 29, 2011 - 3:39 PM
stephen_lee 3vz and 2jzge have very similar power outputs.
3... Sep 29, 2011 - 7:52 PM
Smaay 2JZ-GE no not quite, the 3VZ-FE only makes about 1... Oct 3, 2011 - 1:58 PM
stephen_lee 3VZFE gets 185/189 for years 92-93. Years 94+ got ... Oct 3, 2011 - 2:46 PM
stephen_lee 335/317 wheel hp/tq on 9psi.
MR2 3VZFTE dyno run,... Oct 3, 2011 - 3:11 PM
95CelicaST There was no such thing as a 94+ 3VZ-FE for the US... Oct 3, 2011 - 3:15 PM
stephen_lee I know the US only had the 3VZFE in 92/93. It made... Oct 3, 2011 - 3:19 PM
Smaay you cant compare power to PSI! prime example w... Oct 4, 2011 - 2:08 PM
stephen_lee QUOTE (Smaay @ Oct 4, 2011 - 2:08 PM... Oct 4, 2011 - 4:36 PM
95CelicaST Less off the shelf performance parts and the 3VZ i... Oct 4, 2011 - 5:06 PM
stephen_lee as stated, if you want to turbo w/o a full engine ... Oct 6, 2011 - 10:36 AM
Kwanza26 QUOTE (stephen_lee @ Oct 6, 2011 - 3... Nov 29, 2011 - 11:29 AM
JenryKaly Great content and very helpful thank and keep up t... Nov 25, 2011 - 4:07 AM
AlexLabin Great content and very helpful thank and keep up t... Nov 28, 2011 - 6:23 AM
njccmd2002 Great content and very helpful thank and keep up t... Nov 28, 2011 - 8:28 AM
Caspermart7 the 1MZ is a much better platform. newer technolog... Dec 2, 2011 - 6:08 AM![]() ![]() |
| Lo-Fi Version | Time is now: June 24th, 2026 - 3:18 AM |
