> master to slave
post Sep 22, 2011 - 11:26 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
here is a question... I dont have a hard line for the master cylinder I installed for the clutch.. whats can i safely use to run from there to the slave on the transmission ????
Always fast and going for the look......
Replies (1 - 13)
post Sep 22, 2011 - 11:40 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
your going to need a rubber line or stainless line some where in between the two because of the engine flexing.........
2nd Gen 3s-gte.... It lives!
97celiman
post Sep 26, 2011 - 10:45 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you shouldn't have to open the system at all. just unbolt the hard line from the transmission and move it out of the way
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 26, 2011 - 8:56 PM
bsamps4
Joined May 16, '10
From Raleigh
you should just buy the hard line from toyota
post Sep 26, 2011 - 9:10 PM
QUOTE (bsamps4 @ Sep 26, 2011 - 9:56 PM) *
agreed.
perfect fit and probably around $20.
post Sep 26, 2011 - 9:46 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
Okay suggestions ... wich one the hard line part order from gt4 or just the regular celica gt manual???? and also why not just a rubber line made for the brake system and get the fittings for that tranny ...
QUOTE (Batman722 @ Sep 26, 2011 - 10:10 PM) *
agreed.
post Sep 26, 2011 - 10:31 PM
clutch hard line #31481-20750
the rubber line #90931-01108 (st204)
This post has been edited by Batman722: Sep 26, 2011 - 10:31 PM
post Sep 26, 2011 - 11:59 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
ok but heres the thing i have a mr2 tranny the e153 but off the mr2.. it has the bleeder line, then going to the frame holding the clutch.. then out of the frame is the rubber line going to the second hard line ... how do u get from the rubber hose you told me to buy then to go to the diffrent kind of slave cylinder .....
QUOTE (Batman722 @ Sep 26, 2011 - 11:31 PM) *
post Sep 27, 2011 - 8:48 AM
I don't understand.
post Sep 27, 2011 - 8:58 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
QUOTE (Batman722 @ Sep 27, 2011 - 9:48 AM) *
I don't understand.
post Sep 29, 2011 - 1:00 AM
timdog1720
Joined Mar 4, '10
From Bronx NY
bump
post Sep 29, 2011 - 7:13 AM
Culpable04
Joined Apr 17, '06
From New Jersey
when I did mine I used my ST205 slave and lines, exactly because I was having issues finding the right hose for the stupid mr2 connection.
you can go to autozone and order a camry V6 manual trans slave and the line from the dealer, or maybe someone has a used one from the ST205 clip / engine set.
Good luck
post Sep 29, 2011 - 9:33 AM
toyotatech3
Joined Jul 30, '04
From colorado
post Sep 29, 2011 - 6:54 PM
trdproven
Joined Aug 2, '05
From Guam
you can just buy compatible hard lines at Napa and bend them accordingly done deal, done it before. Although OEM is game.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: January 15th, 2026 - 9:52 PM
