> Installing headers on 95 Celica GT
post Sep 23, 2011 - 10:04 PM
6thcelestial
Joined Dec 29, '08
From midwest
I need to get advice on putting headers on my 95 GT. Never done this before, but guessing that it is a matter of just removing the old exhaust manifold , and reconnecting the new header up to the exhaust, and bolting it back in. Any advice would be greatly appreciated. I can't drop a lot of cash, but would like to get the best quality I can for the money. Any suggestions on brand, and who to order from would really help too. Also need to know if I need to do a lot of work under the car, or can most be done right under the hood. Thanks in advance. biggrin.gif
Replies (1 - 8)
post Sep 24, 2011 - 12:44 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
in my case it really wasnt hard at all, at first even i was concerned on doing it on my own, so i paid 80 dollars for installation 1st time,
but now with my engine being removed and worked on so many times, i realized its not hard at all, in a scale of 1-10, i would call it 3,(about as hard/easy as replacing sparkplugs)
its pretty much bolt on.
i used ebay sure2win headers. about 115 if im not wrong.
post Sep 24, 2011 - 4:59 AM
matts94celica
Joined Apr 20, '11
From College Station, Tx
Check out the info section there's a how-to on installing header on 7afe. And I figure the 5sfe wouldn't be much different from the 7afe. Its real easy you just need some stuff like wd-40 and let the engine cool and soak the nuts om the head to the exh. Mani. And then on the second piece soak the nuts with it and just work at it. I did my whole exhaust in a day. I removed my whole exhaust and rewelded new pipe in most spots and I put tip on to. Its easy if you have the resources available. Good luck modding your celi.
-Matt
EDIT: as far as the underneath(idk if that's spelled right) or on top of car its about half and half. If you have car ramps they'll help a lot. But a floor jack and a couple jack stands will be ok.
This post has been edited by matts94celica: Sep 24, 2011 - 5:07 AM
post Sep 24, 2011 - 5:29 AM
6thcelestial
Joined Dec 29, '08
From midwest
QUOTE (Malhar95 @ Sep 24, 2011 - 12:44 AM) *
Thanks for the info. Will check out the sure2win headers.
QUOTE (matts94celica @ Sep 24, 2011 - 4:59 AM) *
-Matt
Thanks Matt. By the way how much hp do you really gain??
post Sep 24, 2011 - 8:15 AM
6G96GT
Joined Jan 20, '08
From East Coast
I went with the surewin header on ebay. It bolted right up and I've had it over 2 years now with no probs and no rust (although I did wrap it) and it sounds great with a full exhaust to the back. Definitely noticed upper end power gain but a loss in low end power a bit.
I also had to have the 2nd O2 sensor relocated to the back behind the cat in order to get the CEL to stop throwing an O2 sensor code. It's been working now for a year since I had it relocated.
post Sep 24, 2011 - 1:17 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
do a search, i wrote a review and install guide
never mind, here it is
http://www.6gc.net/forums/index.php?showto...6&hl=header
This post has been edited by Smaay: Sep 24, 2011 - 1:19 PM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 26, 2011 - 8:50 AM
Arsaces
Joined Oct 7, '10
QUOTE (Smaay @ Sep 24, 2011 - 1:17 PM) *
Just installed mine on Saturday, I must say it was a pain in the friggin neck. Every bolt was rusted on, 2 of the studs came out of the engine, on the bottom end I discovered 1 bolt that was already busted off, 1 that wouldn't budge (had to be cut off) and 1 that screwed off with little pressure. Then I find out that 2 of the 3 gaskets that I got with my header were slightly too small, and had to be bent a bit to get them to fit. My header is from Bonehead on ebay, surewin is out, and I cant' get a reply from him on when they will be back in (was supposed to be 3 weeks ago).
Now that the header is on, I am pretty happy. Mainly I am happy that I succeeded and got it installed, I did not notice much gain (we will find out @ my next fillup if I got more mpg's). The sound is noticeable, and it seems like it is changing the more I drive it, maybe I will get a bit more gain as it "breaks in"?
post Sep 27, 2011 - 12:02 PM
6G96GT
Joined Jan 20, '08
From East Coast
Yeah, I think it'll sound better with more time. I noticed the gains in the upper end especially going from 60-75 for example. Also, I did have a high flow cat, perf. resonator, and perf. exhaust with mine at that time so it may have been a little different from your experience. Did you wrap your headers yet? They get extremely hot.
This post has been edited by 6G96GT: Sep 27, 2011 - 12:03 PM
post Sep 29, 2011 - 6:57 PM
trdproven
Joined Aug 2, '05
From Guam
the only thing is use 6pt sockets if possible. you will have to remove the manifold cover, and whatever is blocking on the left side, i think I took out the alternator or the bracket somewhere there. use a good gasket, the bottom reconnects to your stock, reuse your sensor, you will lose the top cat and have none left if you don't have the second one under. just understand your low end torque will be noticeably lost.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 11th, 2026 - 12:12 PM
