> Drifting platform
post Sep 26, 2011 - 5:11 PM
What would be the best shell to start a drift car?
toyota, the ae86 but is this just because its a legend?
not a supra, cant afford one. too expensive. and the older ones are too heavy.
also not a convertible. for obvious reasons.
post Sep 26, 2011 - 10:49 PM
mak5603
Joined Oct 20, '08
Ae's don't have enough power to be competitive unless you sr or equivalent swap them, IMO.
S chassis is easiest, cheapest, bossest, again IMO. There are conversion kits for any swap you'd want: LSx, sr, rb, 1jz, 2jz, ca18, ka24, old chevy 350 if that floats your boat, etc. Tons of aftermarket support. TONS!!
I'm personally going to build a 1jz s14 for drifting, just gotta do a couple other things in life real quick.
2014 Toyota Rav4 XLE
post Sep 27, 2011 - 12:12 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (njccmd2002 @ Sep 26, 2011 - 3:11 PM) *
F*ck you :'(, FC!!!
This post has been edited by SupraKid: Sep 27, 2011 - 12:57 AM
post Sep 27, 2011 - 12:13 AM
block
Joined Jul 27, '06
From Soda
240sx or ae86.
post Sep 27, 2011 - 12:38 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Cressida
post Sep 27, 2011 - 4:16 AM
whatthe
Joined Aug 13, '08
From Australia
A S chassis with a simple sr20det or rb with stiff coilovers. Easy.
post Sep 27, 2011 - 6:32 AM
Culpable04
Joined Apr 17, '06
From New Jersey
sorry but Supra MK II is the lightest of the Supras
MK II
Curb weight 1,361 kg (3,000 lb
MK III
1,537 kg (3,389 lb) (manual)
1,595 kg (3,516 lb) (automatic)
MK IV
1,460 kg (3,219 lb) (non-turbo)
1,550 kg (3,417 lb) {turbo}
that said, the very best car to start drifitng is the cheapest one you can get, try to find one that someone elses has gotten somewhat ready for drifitng for very cheap, chances are this car wont survive the learning process ( assuming you take this serious ) so just find something cheap to learn on, then you can look around for whatever you would love drift on.
if I was to do it, I would focus on an MK II, P type, they come with LSD, 5mge with around 180 which is enough power to get the tires lose but not too much to become an issue with a beginner, and if for some miracle I dont crash the car or dont bend the chassis banging it on every wall lol, a 2jz fits right in.
post Sep 27, 2011 - 12:40 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Stevenson, gtf off wikipedia..You are right, but those numbers are grossly off.
Supras=not drift cars.....Drift cars IMO are usually:
-Pretty lightweight(under 3k)
-Have appeared in Initial D
-Have a large drifter support of people to tell you your jdm sticker and yellow fogs are mad tyte y0
-Able to be pushed to their limits without fear of hurting the car(ie beater)
-Aren't luxury cars to start with(supra IS, weather you think so or not, 240sx are not)
-Obviously rwd and NA
This post has been edited by SupraKid: Sep 27, 2011 - 12:44 PM
post Sep 27, 2011 - 1:25 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Suprakid, howcome you say an NA car would make a better drift platform?
Just curious.
My Celica!
post Sep 27, 2011 - 1:58 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
MX83 Cressida.
**** Photobucket
post Sep 27, 2011 - 2:11 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (jordisonjr @ Sep 27, 2011 - 12:25 PM) *
Just curious.
Throttle response is the only thing I can think of. Most cheap drift cars (i.e. 240SX) benefit from a turbo. Breaks the tires loose faster.
June '12 COTM
'95 AT200
post Sep 27, 2011 - 2:37 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
QUOTE (95CelicaST @ Sep 27, 2011 - 1:58 PM) *
MX83 Cressida.
This.
Buy a roller and drop in an N/A 2j along with Supra MK3 tranny and LSD
End up with this:
Use it like this:
~bloodMoney
post Sep 27, 2011 - 3:25 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
rx7 either gen1 or 3
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Sep 27, 2011 - 4:19 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
^If you can afford to blow the motor up all the time.
My Celica!
post Sep 27, 2011 - 5:50 PM
azian_advanced
Joined Apr 18, '05
From Calgary
S chassis would be my ideal starting point.. they're inexpensive, lightweight, decent wheelbase, low center of gravity (especially on coilovers), lots of aftermarket support and an abundance of spare parts for cheap which you'll need since you'll literally be abusing the **** out of it.
post Sep 27, 2011 - 6:45 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
QUOTE (jordisonjr @ Sep 27, 2011 - 5:19 PM) *
people blow motors because they are retards, rotaries have been proved time and time again in both WRC and 24 hour le mans. The key is to keep the oil and water temps cold, and open the exhaust fully. uncle had an rx7 and drove it year round with no problems. All it takes is a little research and its fantastic. I understand many people dont like them but they are great motors and are just as reliable as anything else.
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Sep 27, 2011 - 7:13 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Any S chassis nissan
Import a JZX90 or JZX100 mark II or chaser, already: 1jz-gte, manual and lsd.
Lots of people in aus drift KE70 corollas (or ae71), but your in the same situation as an AE86. The chassis is fine, but the suspension needs a lot of work to be viable. And as far as the engine goes dropping in a 4a-gze or a 4a-ge 20 valve with a turbo would do. Or a CA, SR, 3s, 1j, 2j, RB, LS1
This post has been edited by Cuts_the_Pilot: Sep 27, 2011 - 7:17 PM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Sep 27, 2011 - 9:19 PM
would a mki mr2 be something to modify?
andrew, i dont hate supras, they are just too big for that.
would be great to import a chaser...
sometimes i think maybe modify a 1st gen celica....
its just something crazy that came up the other day...
an ae86 would be a great start...
but idk.... Nissans sound good... ill just keep this in mind.
post Sep 27, 2011 - 9:37 PM
Culpable04
Joined Apr 17, '06
From New Jersey
any mid engine car would be a very steep learning curve.
they are not too popular on drifting.
not a bad deal here
there was another one for a similar price, original owner, who moved from Texas less than a year ago, red, totally stock, but can't find it, is probably sold by now
post Sep 27, 2011 - 9:44 PM
spy00005
Joined May 15, '09
From yonkers, NY
Don't know if you ever seen this but i found it and thought it had some good info its very basic on drifting itself if you seen it then never mind
http://youtu.be/eLDejTKH388
but i mean Keiichi Tsuchiya FTW - i got the "drifting bible" but haven't gotten around to watching it definetly a good thing to look over if you have some time to kill
also good luck i still think drifting is pretty sick if its done right.
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
Lo-Fi Version Time is now: June 25th, 2026 - 3:19 AM
