> Please Help!, pro's needed!
post Oct 1, 2011 - 1:28 AM
j0ch0a94ST
Joined Sep 27, '07
From Raleigh, NC
K guys so its been months now and my celica is still down on power. I've had other people who have had 6th gen st's drive it and they say the same. Like I stated earlier in the thread my friend advanced the timing almost all the way to get the thing operating normal or at least semi-normal. However there is still a noticeable power loss and I'm having trouble diagnosing it. I'm over at my friends house and we are going to vacuum test it tomorrow as well as retard the timing back to factory to try and trace the problem. If you guys have any suggestions as to what else might cause the power loss it would be greatly appreciated.
The following have been ruled out:
spark plugs(replaced)
spark plug wires(replaced)
fuel filter(replaced)
injectors(do not contain water)
No check engine light or other idiot lights so NO code to diagnose
Distributor has no water and appears to be working fine
Thanks again guys
- j0ch0a94ST   Please Help!   Oct 1, 2011 - 1:28 AM
- - ST205WRC   has there been any other work done. did it just ra...   Oct 1, 2011 - 7:48 AM
- - presure2   timing.   Oct 1, 2011 - 9:28 AM
|- - 6G96GT   QUOTE (presure2 @ Oct 1, 2011 - 10:2...   Oct 1, 2011 - 10:34 AM
- - Neon90424   I read fuel filter but not fuel pump   Oct 1, 2011 - 9:49 AM
- - j0ch0a94ST   Sorry guys. Little back story. Took the car to the...   Oct 1, 2011 - 11:48 PM
- - Neon90424   my 7GC did went Subie on me! was the coil on p...   Oct 2, 2011 - 1:15 AM
- - Bitter   Failing cam position sensor? Bad ECM? Bad knock se...   Oct 2, 2011 - 9:38 AM
- - stephen_lee   you should replace the cap n rotor. also you coul...   Oct 2, 2011 - 10:19 AM
- - j0ch0a94ST   sorry guys I meant to put that I've already re...   Oct 2, 2011 - 11:34 AM
- - SwissFerdi   Just to get a safe answer, pull the cover off...   Oct 2, 2011 - 1:20 PM
- - stephen_lee   turn engine till notch on crank pulley lines up wi...   Oct 2, 2011 - 1:50 PM
|- - stephen_lee   QUOTE (stephen_lee @ Oct 2, 2011 - 1...   Oct 14, 2011 - 9:08 AM
|- - j0ch0a94ST   QUOTE (stephen_lee @ Oct 2, 2011 - 1...   Oct 15, 2011 - 7:37 PM
- - Rav4Race   may i know what kind of power loss is it? is turbo...   Oct 3, 2011 - 2:50 AM
|- - j0ch0a94ST   QUOTE (Rav4Race @ Oct 3, 2011 - 2:50...   Oct 4, 2011 - 9:33 AM
- - Neon90424   lol no turbo spool at all!   Oct 3, 2011 - 8:45 AM
- - j0ch0a94ST   Here's a 0-55ish video we took to show how slo...   Oct 13, 2011 - 6:57 PM
|- - d3ath2009   QUOTE (j0ch0a94ST @ Oct 13, 2011 - 6...   Oct 13, 2011 - 7:02 PM
|- - j0ch0a94ST   QUOTE (d3ath2009 @ Oct 13, 2011 - 7...   Oct 13, 2011 - 9:16 PM
- - trdproven   timing belt off? affecting your ignition timing. ...   Oct 13, 2011 - 7:38 PM
- - Bitter   that does sound a bit sluggish and I used to own a...   Oct 13, 2011 - 9:11 PM
- - SwissFerdi   ^ Truth. 7A is "slow," but that not slow...   Oct 13, 2011 - 9:55 PM
- - Neon90424   Well an engine is basically a giant airpump if it ...   Oct 15, 2011 - 9:23 PM
- - stephen_lee   air will leak pass the rings when u spin the motor...   Oct 16, 2011 - 1:13 PM
|- - j0ch0a94ST   QUOTE (stephen_lee @ Oct 16, 2011 - 1...   Oct 16, 2011 - 7:28 PM
- - ricochet1490   did you get everything figured out?   Oct 23, 2011 - 10:45 PM
|- - j0ch0a94ST   QUOTE (ricochet1490 @ Oct 23, 2011 - 11...   Oct 24, 2011 - 11:38 PM
- - rave2n   This may sound stupid, but is your e-brake stuck i...   Oct 25, 2011 - 2:38 PM
|- - j0ch0a94ST   QUOTE (rave2n @ Oct 25, 2011 - 3:38 ...   Oct 27, 2011 - 9:29 AM
- - Smaay   yes you will hear that air sound, thats totally no...   Oct 25, 2011 - 3:20 PM
- - ricochet1490   fuel pressure regulator? I don't know... what...   Oct 27, 2011 - 10:05 AM
- - Needles   did you check your air filter^? hahaha   Oct 27, 2011 - 11:22 AM
- - stephen_lee   Check the lines to the MAP sensor. Might also tr...   Oct 27, 2011 - 12:18 PM
- - ricochet1490   ^x2 = if water got in an around that MAP and someh...   Oct 27, 2011 - 12:42 PM
|- - xrav22   QUOTE (ricochet1490 @ Oct 27, 2011 - 1...   Oct 27, 2011 - 2:05 PM
- - j0ch0a94ST   So we tested the vacuum and it was at 21hg, I unpl...   Nov 5, 2011 - 6:43 PM
- - j0ch0a94ST   UPDATE: We replaced the MAP sensor as well as the ...   Nov 7, 2011 - 3:11 PM
- - j0ch0a94ST   EGR and injectors checked out   Nov 7, 2011 - 5:17 PM
|- - j0ch0a94ST   QUOTE (j0ch0a94ST @ Nov 7, 2011 - 6...   Dec 3, 2011 - 6:05 PM
- - kurt95gt   might sound stupid but when my battery was going b...   Dec 3, 2011 - 8:24 PM
- - j0ch0a94ST   QUOTE (kurt95gt @ Dec 3, 2011 - 8:24...   Dec 4, 2011 - 12:04 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 11:09 PM
