> 3s-gte rebuild
post Oct 6, 2011 - 3:41 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Hello!
I got 1994 st205 celica. now it's time to rebuild the engine. it started knock very bad. i think it's camshaft bearings.
The knock started when i was driving, i stop and the oil was wery low.
I need advice where to buy new parts. i'm from Finland.
I got the engine out and now i have a problem. i can't get the trans off the engine.
i think every bolt is off.
help please!
here is some pictures
intake side
exhaust side
- Gt4Driver   3s-gte rebuild   Oct 6, 2011 - 3:41 PM
- - bsamps4   Problem #1 Your starter is still attached to the ...   Oct 6, 2011 - 7:16 PM
- - Neon90424   www.ebay.co.uk should have sellers that sell to eu...   Oct 6, 2011 - 10:18 PM
- - Gt4Driver   Ok. thanks guys. need to remove the starter. then ...   Oct 7, 2011 - 12:27 AM
|- - malpaso   QUOTE (Gt4Driver @ Oct 7, 2011 - 7:2...   Oct 7, 2011 - 4:30 AM
- - Rav4Race   i use to get my parts in malaysia. Always the best...   Oct 7, 2011 - 6:22 AM
- - Gt4Driver   Today i got the trans off   Oct 10, 2011 - 1:50 PM
- - Neon90424   looks like a clutch kit could do good for you...th...   Oct 10, 2011 - 3:12 PM
- - Gt4Driver   Yes it looks like it's time to chance it is t...   Oct 10, 2011 - 11:50 PM
- - Neon90424   they are the same I believe   Oct 11, 2011 - 6:40 AM
- - Sunny   Hi, a short list of which parts you are seaching ...   Oct 11, 2011 - 8:03 AM
- - Gt4Driver   Hi. I need new clutch, main and rod bearings, bott...   Oct 11, 2011 - 10:50 AM
- - Sunny   Hi, get the parts from toyota, here a link that h...   Oct 11, 2011 - 12:50 PM
- - Gt4Driver   well. i think the bearings are bad, cause i was lo...   Oct 11, 2011 - 1:13 PM
- - Sunny   Hi, do not try to safe money, this can couse the ...   Oct 11, 2011 - 4:12 PM
- - Smaay   the knock is defiantly from the crank bearings. th...   Oct 11, 2011 - 5:17 PM
- - Gt4Driver   hello. it seems to be my 3 cylinder rod bearing is...   Oct 16, 2011 - 11:04 AM
- - Neon90424   they sell all 4 together and its not that expensiv...   Oct 16, 2011 - 12:51 PM
- - bsamps4   It would be crazy to not replace all bearings...   Oct 16, 2011 - 3:50 PM
- - Gt4Driver   ok. So im gonna replace all bearings. In toyodiy ...   Oct 17, 2011 - 1:54 PM
- - Neon90424   the std, .025 etc are in case you have spun a be...   Oct 17, 2011 - 4:44 PM
- - bsamps4   Take caution. You need to have your crank journals...   Oct 17, 2011 - 7:58 PM
|- - Mr_Tee   QUOTE (bsamps4 @ Oct 17, 2011 - 7:58...   Oct 23, 2011 - 2:27 AM
- - Gt4Driver   RE: 3s-gte rebuild   Oct 21, 2011 - 4:30 PM
- - bsamps4   you may be looking at a new crank sir...if i'm...   Oct 21, 2011 - 5:58 PM
- - Gt4Driver   what do you think about this? Do i need a new cran...   Oct 23, 2011 - 7:47 AM
- - enderswift   that doesn't look bad. You're really only ...   Oct 23, 2011 - 7:15 PM
- - bsamps4   The close up picture looks a lot better than the o...   Oct 24, 2011 - 7:21 PM
- - Gt4Driver   Ok. the car was running great before the bearing ...   Oct 24, 2011 - 11:37 PM
- - bsamps4   You need to have the crank machined first and ask ...   Oct 25, 2011 - 12:22 PM
- - Gt4Driver   Hello! Got the crank back from machineshop, st...   Nov 4, 2011 - 2:30 AM
- - bsamps4   Sounds great! Did you put new rings on the pis...   Nov 4, 2011 - 10:12 AM
- - Gt4Driver   Old rings and pistons.   Nov 4, 2011 - 10:27 AM
- - bsamps4   If you're running the old rings make sure to c...   Nov 7, 2011 - 11:22 AM
- - Gt4Driver   put the engine in today   Nov 13, 2011 - 7:34 AM
- - Neon90424   RE: 3s-gte rebuild   Nov 13, 2011 - 10:11 AM
- - Gt4Driver   Few pics   Nov 13, 2011 - 1:46 PM
- - bsamps4   Great pics man! Hope it runs as good as it loo...   Nov 14, 2011 - 9:13 AM
- - Gt4Driver   Little progress   Nov 15, 2011 - 4:42 AM
- - Gt4Driver   Ok. one question. My timing belt side driveshaft w...   Nov 15, 2011 - 7:12 AM
- - bsamps4   No, it needs to click in all the way. The transmis...   Nov 15, 2011 - 9:36 AM
- - Gt4Driver   So do i just need to hammer it on? The other side ...   Nov 15, 2011 - 9:42 AM
- - rave2n   I had to tap mine in with a deadblow to an end of ...   Nov 15, 2011 - 2:42 PM
- - Gt4Driver   Oil sanwich plate install for oil pressure gauge a...   Nov 15, 2011 - 3:51 PM
- - Neon90424   my mechanic was preocupied by the oil press sensor...   Nov 15, 2011 - 4:21 PM
- - Gt4Driver   Thanks for warning. i'll check that   Nov 16, 2011 - 1:05 AM
- - Gt4Driver   That fu***** driveshaft wont go in. Been hammer...   Nov 16, 2011 - 3:41 PM
- - bsamps4   Any way you could pull it out and take a pick of w...   Nov 16, 2011 - 4:06 PM
- - Gt4Driver   Ok. i'll take a pick tomorrow, now i need to g...   Nov 16, 2011 - 4:14 PM
- - Gt4Driver   it's in! just take it off and put it back....   Nov 17, 2011 - 4:49 PM
- - Gt4Driver   Ok. It's time to fire it up Hope everything...   Nov 20, 2011 - 4:19 AM
- - Gt4Driver   No it wont start. starter just klicks.   Nov 20, 2011 - 7:54 AM
- - Gt4Driver   I hammered my starter and it starts to work   Nov 20, 2011 - 9:33 AM
- - Neon90424   sounds like a new starter is in order...   Nov 20, 2011 - 9:44 AM
- - Gt4Driver   Yes i think so. but it works now. Engine runs grea...   Nov 20, 2011 - 11:20 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 12:52 PM
