> car wont turn over, car wont turn over
post Oct 12, 2011 - 12:38 PM
zfjohnson07
Joined Apr 11, '09
Alright, i changed this since no one could help me on the fuel line. I'm thinking my wires are crossed or something, but whenever i try to turn the key i can hear a relay click thats its, nothing else, no its not the starter!!! well then when i try to take the key out it will not go all the way left, so i have to unhook the battery and then it will come out free. Any thoughts as to what it might be? I'm thinking of just goign to a junk yard and getting a fuse box on the driver side so i can see if that might be the problem...
This post has been edited by zfjohnson07: Nov 12, 2011 - 7:14 PM
post Nov 12, 2011 - 7:14 PM
zfjohnson07
Joined Apr 11, '09
bump, can anyone help me!
post Nov 12, 2011 - 7:32 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
was/is the car an automatic?
post Nov 12, 2011 - 8:17 PM
zfjohnson07
Joined Apr 11, '09
Automatic. I did read forums pertaining to this, checked the ground to the battery made sure it is clean,
post Nov 12, 2011 - 8:42 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
neutral safety switch.
try shorting the pin that has a small wire on the starter to 12v. with key on. see if the car starts.
post Nov 12, 2011 - 9:07 PM
zfjohnson07
Joined Apr 11, '09
Idk... That's a good thought but I have that problem with my other celica and the key would come out, I'd usually push it
post Nov 12, 2011 - 9:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if your trans is not in park, the key wont come out. (itll stop in the ACC position.) if the trans is not in park or natural it wont crank.
thats why i suggested its there
post Nov 12, 2011 - 9:13 PM
zfjohnson07
Joined Apr 11, '09
Well tomorrow, I will try what I do on my other celica. And what you mentioned ant get back to u
post Nov 13, 2011 - 12:29 PM
zfjohnson07
Joined Apr 11, '09
alright went out there got it to turn over, i checked my wires and i tried making sure they were connecting good, then i plugged the wire harnesses back in and it tried turning over. now the fun part. I mentioned when i was in my wreck my fuel filter was pushed back and right at the connection on the bottom it cracked, i tried repairing it and it still squirted gas everywhere. Would it be a better idea just to go ahead and replace the whole line. Reason im asking is ive already got it disconnected on the bottom half where all i need to do now is disconnect it from the fuel pump, but i need to know where i should get a new line. any help would be appreciated. Thanks
post Nov 13, 2011 - 12:40 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
id go to the dealer for it.
Lo-Fi Version Time is now: September 21st, 2026 - 9:52 AM
