Oct 13, 2011 - 3:14 PM
Enthusiast ![]() Joined Mar 29, '11 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
So as the title goes, I had my car on a lift, engine on and in neutral, and the front passenger wheel was encountering a decent amount of resistance when spinning. I can only guess it's the caliper. Interestingly, the passenger rear is experiencing the same problem, only its the shoes against the drum. A guy I worked with suggested it's a bad caliper, which is also causing uneven pressure distribution in the back locking it up as well. I'm just thinking if the caliper itself is bad, or I just need to bleed the brakes and see if there's stuff in there. What do you guys think? And is the procedure for bleeding pretty easy with these cars? The old horse is pretty weather worn, so I'm worried I might snap something off the release valve when I try and bleed it.
senick Caliper's locking up Oct 13, 2011 - 3:14 PM
stephen_lee the front is seperate from the rear IIRC.
bleedi... Oct 13, 2011 - 3:18 PM
senick Hmm, well I just think it's odd that both brak... Oct 13, 2011 - 3:24 PM
stephen_lee depends on how much load its putting on the wheel.... Oct 13, 2011 - 4:38 PM
senick Well, the wheel won't spin for 5 seconds with ... Oct 14, 2011 - 10:01 AM
xrav22 QUOTE (senick @ Oct 14, 2011 - 10:01... Oct 22, 2011 - 4:33 PM
Galcobar Seized calipers generally are an issue with the sl... Oct 23, 2011 - 10:56 PM
trdproven have you tried driving a decent distance and then ... Oct 25, 2011 - 1:52 AM
Needles you can try rebuilt the 2 little piston of the gal... Oct 25, 2011 - 7:13 PM
Euphoria I had a few problems like this when I had my celic... Oct 26, 2011 - 6:45 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 1:53 PM |
