> idle problems, idle
post Oct 18, 2011 - 4:26 AM
HerosBlade
Joined Mar 22, '09
From Oahu, Hawaii
Hey guys my problem that I am having is that when I hold rpm at 2000 the needle moves up and down while I am pressing the gas at 2000 its not a big up and down its really small. Also I have engine hisation problems when I'm holding a speed like 40mph. I was wondering if anyone had a similar problem and that they fixed it. 95 2.2L 4 Manual trans.
The New Kid on the Block
post Oct 18, 2011 - 8:41 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Do a full tune up first.
do the RPMs change much when you're holding a steady speed when this happens?
post Oct 18, 2011 - 11:33 AM
trdproven
Joined Aug 2, '05
From Guam
tune up is one way to check, plus you can tell by when teh last time you did it or if you didn't do it, . simple check although only the spark plugs, you can easily see the condition of those. if thats not the case, then let us know what else is wrong. sometimes just changing the spark plugs by itself just to test you will determine if thats it and the problem goes away and theyre cheap. but just do the tune up if you havent done so in a while. is the problem also on startup or idle?
This post has been edited by trdproven: Oct 18, 2011 - 11:34 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 18, 2011 - 12:46 PM
HerosBlade
Joined Mar 22, '09
From Oahu, Hawaii
Thanks guys will do just gotta wait for a day off and payday which is friday also go oem ngk or higher???
This post has been edited by HerosBlade: Oct 18, 2011 - 12:47 PM
post Oct 18, 2011 - 1:22 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ngk. i dont believe you can "gain" anything from plugs. only LOSE by putting crappy or multiground plugs in
post Oct 18, 2011 - 2:00 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Change the spark plugs, check for the air filter and fuel filter. Also check if your throttle body is all clogged up.
This post has been edited by dudeofchaos: Oct 18, 2011 - 2:00 PM
post Oct 18, 2011 - 7:30 PM
trdproven
Joined Aug 2, '05
From Guam
yea there could be a number of things but check the easiest things first. we'll guide you through.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 25, 2011 - 7:49 PM
Bigblock
Joined Feb 14, '09
From Mid West
HerosBlade,
Did you get it running right?
Lo-Fi Version Time is now: May 25th, 2026 - 7:15 AM
