Oct 19, 2011 - 1:58 AM
Enthusiast ![]() ![]() Joined Feb 3, '04 From West Windsor, NJ Currently Offline Reputation: 3 (100%) |
(almost) EVERYTHING MUST GO
It's a red GT Coupe with almost 194k miles on it. No sunroof, 6-speaker system for those interested in headliner and door panels. Everything that I can take off myself and isn't too big ships from New Jersey via [your choice]. If it's big/heavy (e.g. the entire interior) or I can't remove it fairly easy (e.g. rear motor mount), I'd rather you pull it yourself. Make an offer for whatever you want. For parts that come in 2s (or 4s, or whatever), I'd rather sell them as a set. Recently changed (within the past year): Front, Rear, Tranny Mounts (Anchor brand, last month) Sleeved the pipe that runs from the flex pipe to the cat. There was a flange there, now there's a sleeve because the stress that the bad mounts caused broke the flange (last month) Air Intake - Replaced with K&N and black metal short ram. Practically new (less than 5,000 miles on those) Timing Belt, Water Pump (new, not rebuilt), Thermostat, Water Pump Gasket (this spring, less than 15k miles ago) Spark Plugs (NGK Iridium), Spark Plug Wires (NGK OE), Distributor Rotor, Distributor Cap Belts (Power Steering, Alternator, and whatever the third one is) Valve Cover Gasket, Tube Seals Struts (KYB), Strut Mounts, boots, and bump stops Left Axle/CV/whatever it's called Also changed, but a little over a year ago: Flex Pipe Things you don't want because they're in crap condition: Left axle The power steering system as a whole - if you want certain parts, I'll inspect them and tell you the condition, but something somewhere is leaking so you definitely don't want the whole system Trunk lift struts Left low-beam Cabin air filter Certain parts of the interior - ask for specifics and I'll send you pics of them Head unit (aftermarket, CD player has problems) Gauges (Reverse Glow, but with LED issues) Driver's side window regulator/motor Front right bottom speaker from 6-speaker system Non-Standard Parts: TRD Shift Knob K&N filter and short ram intake (see "recently changed") Wheels are 17" Scion tC rims (not the new ones). Pretty bad curb rash on the rims of all 4; BARE RIMS, I had to move the tires to the new car Tanabe Lowering Springs. 2.2" in the front, 1.5" in the back. Not sure if the clutch is OEM. I just know it was changed before I got it (around 80-90k?). SOLD (or promised to people): Air bags + controller Alternator Climate control unit (the box with the knobs and the two cables) Valve cover + nuts Window trim Anything else, make an offer! This post has been edited by Rider: Jan 15, 2012 - 6:20 AM |
Rider FS: Parting out '94 GT Coupe Oct 19, 2011 - 1:58 AM
Spider77 Window Trim (Both driver/passenger front and rear)... Oct 19, 2011 - 5:43 AM
shaq What color is the car? I'm looking to buy the ... Oct 19, 2011 - 7:37 AM
str8thugginit4ya Any pics of the door panels? Oct 19, 2011 - 9:19 AM
foxcraze i need three female plugs with about 6 inches of w... Oct 19, 2011 - 7:15 PM
Rider NOTE TO EVERYONE: I'll be posting daily update... Oct 19, 2011 - 10:49 PM
kingcarlito4991 are the front seats in good condition i live in ne... Oct 20, 2011 - 3:37 PM
spy00005 how much for CC unit and MAP light? Oct 20, 2011 - 3:39 PM
Rider QUOTE (kingcarlito4991 @ Oct 20, 2011 - ... Oct 20, 2011 - 11:12 PM
carlc376 Do you have the center console ashtray? Oct 21, 2011 - 1:46 PM
Jaws4God stock muffler? Oct 21, 2011 - 3:09 PM
Spider77 $10 shipping, as long as its in good conditio... Oct 21, 2011 - 3:55 PM
Rider QUOTE (carlc376 @ Oct 21, 2011 - 2:4... Oct 22, 2011 - 3:11 AM
denis pm! Oct 22, 2011 - 6:29 AM
advancetoyota got pics of the front seats??? Oct 22, 2011 - 8:47 AM
LimitedGT4 do you have the gt rear disc brake assembly? and h... Oct 22, 2011 - 3:20 PM
rkelly_83543 How much for the driver's side tail light ship... Oct 22, 2011 - 6:55 PM
jiggy2dmax I need the center bezel..(the one around the head ... Oct 22, 2011 - 9:15 PM
Rider ^ ^ ^ I'll have specific replies for you guys ... Oct 23, 2011 - 1:34 AM
94celicadude Any chance you still have the two knobs from the h... Oct 23, 2011 - 2:15 PM
denis I will need all the cruise control sistem such as ... Oct 23, 2011 - 3:25 PM
hjesse11 how old are the lowering springs and how much woul... Oct 24, 2011 - 1:00 PM
Rider QUOTE (94celicadude @ Oct 23, 2011 - 3... Oct 24, 2011 - 10:08 PM
Rider OMG PICS!!
Front seat pics were sent to t... Oct 24, 2011 - 10:47 PM
foxcraze "i need three female plugs with about 6 inche... Oct 25, 2011 - 2:56 AM
Rider QUOTE (rkelly_83543 @ Oct 22, 2011 - 7... Oct 24, 2011 - 10:54 PM
Celicarguy I could use the air bags & air bag controller ... Oct 25, 2011 - 3:03 AM
Rider QUOTE (Celicarguy @ Oct 25, 2011 - 4... Oct 25, 2011 - 7:40 AM
Celicarguy The Driver's side air bag is easy - just unbol... Oct 25, 2011 - 8:17 AM
Rider QUOTE (Celicarguy @ Oct 25, 2011 - 9... Oct 25, 2011 - 12:44 PM
Celicarguy I'm sure they are fine - I don't know of a... Oct 25, 2011 - 11:19 PM
rkelly_83543 PM sent Oct 26, 2011 - 8:29 PM
eduardorq Do you have the cruise control cover?
i would be i... Oct 28, 2011 - 10:39 AM
sbennett Do you still have the alternator? Only if it's... Oct 28, 2011 - 12:11 PM
crwarrior hey!! do you have the steering wheel by an... Oct 28, 2011 - 12:17 PM
Rider QUOTE (Celicarguy @ Oct 26, 2011 - 12... Oct 29, 2011 - 5:09 PM
foxcraze Hey man how much for those three harness plugs nev... Oct 29, 2011 - 5:26 PM
Celicarguy Am still interested in the airbags/ctlr if availab... Oct 29, 2011 - 11:06 PM
Rider QUOTE (foxcraze @ Oct 29, 2011 - 6:2... Oct 31, 2011 - 7:05 PM
JasonTX drivers side window regulator? shied to texas 7788... Oct 31, 2011 - 9:56 PM
Rider QUOTE (JasonTX @ Oct 31, 2011 - 10:5... Nov 1, 2011 - 1:19 AM
ricochet1490 i'll answer this ^ for him lol. it's the ... Nov 1, 2011 - 9:34 AM
Rider QUOTE (ricochet1490 @ Nov 1, 2011 - 10... Nov 1, 2011 - 2:29 PM
Ted95 theres no spoiler right? Nov 5, 2011 - 7:28 PM
Rider QUOTE (Ted95 @ Nov 5, 2011 - 7:28 PM... Nov 6, 2011 - 4:05 AM
Originalfuture If the driver seat is in good mechanical condition... Nov 6, 2011 - 7:57 PM
Originalfuture WTB drivers seat??? Inbox me if you have to sell. Nov 6, 2011 - 8:48 PM
Originalfuture Need Driver's seat inbox me. Nov 6, 2011 - 8:54 PM
Rider QUOTE (Originalfuture @ Nov 6, 2011 - 8... Nov 9, 2011 - 1:15 AM
Celicarguy Tried to PM you but your inbox is full. Will PM yo... Nov 10, 2011 - 1:31 AM
kamax the black plastic thing between the hood and the b... Nov 10, 2011 - 5:41 AM
Rider QUOTE (kamax @ Nov 10, 2011 - 5:41 A... Nov 15, 2011 - 3:27 PM
Celicarguy Your inbox is full again. I need to check my car t... Nov 16, 2011 - 2:11 AM
michlowrider Looking for the plastic trim inside the rear of ca... Nov 14, 2011 - 11:46 PM
dsaia I’m selling:
• OEM Genuine Mudguards (Set of 4 w/ ... Nov 15, 2011 - 1:21 AM
ricochet1490 ^ HiJACK
on the main buying selling page there is ... Nov 15, 2011 - 1:38 AM
matts94celica Inbox full Nov 16, 2011 - 9:17 AM
Chockomon Do you have a spoiler? Nov 16, 2011 - 2:44 PM
Rider QUOTE (Chockomon @ Nov 16, 2011 - 2... Nov 18, 2011 - 11:53 AM
foxcraze any new status on the parts listed in the past thr... Nov 18, 2011 - 9:44 PM
Main-Character88 got the center lid thing with pull out cupholders? Nov 20, 2011 - 6:27 AM
Rider QUOTE (Main-Character88 @ Nov 20, 2011 ... Nov 23, 2011 - 5:59 PM
kingcarlito4991 how much for both door sills shipped to 12553 if t... Nov 23, 2011 - 6:51 PM
Ruroniarc Washer Fluid Pump shipped to 02148? Nov 26, 2011 - 3:33 AM
Rider QUOTE (kingcarlito4991 @ Nov 23, 2011 - ... Dec 1, 2011 - 12:51 AM
Celicarguy Hey Rider,
Still waiting for you to ship the airb... Dec 13, 2011 - 3:26 AM
Rider QUOTE (Celicarguy @ Dec 13, 2011 - 3... Dec 13, 2011 - 11:02 PM
R4R44V15 I'm looking for interior headlining clips... Dec 19, 2011 - 1:35 AM
SupraKid Your PM box is full. Dec 19, 2011 - 11:52 AM
irocknikes74 PM me about air intake im interested with price Dec 20, 2011 - 10:03 PM
Ted95 full inbox, pm'd saved ready to send Dec 21, 2011 - 4:24 PM
Rider Holy crap, replies! PM'd SupraKid. Also, i... Dec 22, 2011 - 7:34 PM
R4R44V15 QUOTE (Rider @ Dec 22, 2011 - 8:34 P... Dec 25, 2011 - 11:47 PM
foxcraze Hey man anything on those plugs yet? Dec 22, 2011 - 8:32 PM
mkernz22 how much for the six speaker door panels? Dec 25, 2011 - 11:52 PM
Rider QUOTE (mkernz22 @ Dec 25, 2011 - 11... Dec 29, 2011 - 3:58 AM
boomer looking for r/r hub and brg assy must be for dis... Dec 29, 2011 - 7:54 AM
Rider QUOTE (boomer @ Dec 29, 2011 - 7:54 ... Jan 3, 2012 - 6:12 PM
SallyGloryShine I need both hood hinges. Gimme a price, you can ge... Jan 4, 2012 - 6:29 PM
Rider QUOTE (SallyGloryShine @ Jan 4, 2012 - 6... Jan 13, 2012 - 9:51 PM
Jokester Hey, do you still have the tC wheels? Does it come... Jan 14, 2012 - 12:56 AM
Rider QUOTE (Jokester @ Jan 14, 2012 - 12... Jan 15, 2012 - 3:47 AM
Jokester QUOTE (Rider @ Jan 15, 2012 - 12:47 ... Jan 15, 2012 - 4:29 AM
taibones are you selling the fenders Jan 14, 2012 - 10:22 AM
Rider QUOTE (taibones @ Jan 14, 2012 - 10... Jan 15, 2012 - 3:50 AM
denis still have the cruise control for sale? you have ... Mar 25, 2012 - 6:49 PM
Syaoran Do you have the throttle body (whole thing, includ... Mar 26, 2012 - 9:48 PM
blackceclia0823 Do you have the upper door speaker covers for both... Mar 26, 2012 - 11:07 PM
Originalfuture WTB Drivers side seat.
If seat functions properly... Mar 27, 2012 - 11:04 AM
conus00 What shape are all three trunk panels (also do you... Mar 27, 2012 - 12:35 PM
Special_Edy Id be super interested in the manual shifter boot,... Mar 27, 2012 - 12:36 PM
Warapparel how much for the kyb set up shipped to 92109? Mar 27, 2012 - 1:06 PM
WhipCreamCelica shift boot and shift boot frame if you dont mind? ... Mar 27, 2012 - 2:48 PM
eman2492 both front seats, shipped to 55432? Mar 28, 2012 - 11:45 AM
Detatch QUOTE (Rider @ Oct 19, 2011 - 1:58 A... Mar 29, 2012 - 2:40 AM
toyota_guy how much do you want for the ecu? Mar 31, 2012 - 7:11 PM
conus00 Is this thread still alive? Apr 1, 2012 - 10:17 PM
DaCCelica94 hows the front passenger spindle? Apr 20, 2012 - 8:32 AM
Rider The forum will only let me include so many quotes,... Apr 27, 2012 - 2:59 PM
superman8589 Do u have pistons? If u do and willing sell them I... Apr 28, 2012 - 12:54 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:28 PM |
