Oct 22, 2011 - 12:08 AM
Enthusiast Joined May 24, '11 From Glendale, AZ Currently Offline Reputation: 0 (0%) |
So I just bought my 2nd Celica. It's a convertible and I got if for a song. But... It won't go backwards.
It's a '95 with the 2.2 and an A140E transmission. It drives forward just fine, slips through all 4 gears as expected, power seems to go to the wheels just fine. But when I put it in reverse, I hear the RPMs dip just a little, but no backwards movement. When I put the front end on jackstands both wheels will start spinning when it goes into reverse, but when it's on the ground, no real power is transmitted to the engine. It almost seems like the torque converter is working fine in forward, but not in reverse. I've checked the fluid levels and the transmission fluid is a little high (at the full mark even when cold) and the differential fluid is just under the threads of the fill plug. Now on the way home today, the check engine light went on and I did a Google search to figure out the error codes. I followed the procedure to diagnose the check engine light by shorting the E1 and TE1 terminals. The check engine light indicated a code 71 (EGR system). So fine, I'll deal with that. But I also noticed the O/D light blinking at me. So I did some research and the O/D light was giving a code 63. Front what I've researched this indicates a problem with transmission solenoid #2. Now replacing a solenoid sounds much easier than replacing a transmission, so I'm hopeful. But at the same time, I would think that if this solenoid was bad, I would have more problems than just the Reverse gear. I would love to get any ideas, comments, etc. Am I on the right path? This post has been edited by warthog1: Oct 22, 2011 - 12:19 AM |
warthog1 Advice on Transmission problem - No Reverse Oct 22, 2011 - 12:08 AM
Spider77 I feel your pain when it comes to the A140E....but... Oct 22, 2011 - 11:36 AM
warthog1 Just to close out this problem, I did the followi... Feb 7, 2012 - 1:27 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:52 AM |
