> Big leak when it rains.help!!
post Nov 5, 2011 - 1:21 PM
Sloo94GT
Joined Oct 8, '11
From Manassas VA
when it rains my driver side floor board gets soak so bad when you put your foot on the floor the water gushes out. i have a 94 celica gt with sun roof. i need to get this fixed be for the snow comes. if anyone has a diagram of drain tubes can you post them. i think its coming from the trim panel where the wipers sit. any help would be great.
Replies (1 - 3)
post Nov 5, 2011 - 2:34 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Sunroof drain tube goes down the passenger rear window and into the body where the back seat aligns to.
Check your door seal, and to see if it's going in through the front window/firewall leak
post Nov 5, 2011 - 2:38 PM
Sloo94GT
Joined Oct 8, '11
From Manassas VA
yea its not coming from the back, i tihink its coming from the front left side ill go look around today and see what i find
post Nov 5, 2011 - 7:18 PM
richee3
Joined Jun 29, '08
From Denver
Just did some reading on this not too long ago. Check the grommet where the wiring harness comes into the car. Find the kick panel in the floor board and go straight up from there. A couple of members have had leaks there before that only fills up the drivers side floorboard.
http://www.6gc.net/forums/index.php?showto...hl=drain++tubes
http://www.6gc.net/forums/index.php?showto...=Wet+floorboard
This post has been edited by richee3: Nov 5, 2011 - 7:35 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: September 1st, 2026 - 7:56 AM
