> Will 195/60/15 fit on stock 15x7 aluminum wheels
post Nov 13, 2011 - 1:21 PM
Pyrotechnic
Joined Sep 19, '11
From TX
I know 205/55/15 is the stock size, but seems like tire shops never have them in stock, and forget finding a used one in a pinch. That and they are kinda pricey for a 15" tire.
Will a more commonly found 195/60/15 fit the stock 15x7 aluminum wheels? I've looked at the specs for different tires that size and 7" is an acceptable wheel width but it always listed as the maximum width. Just wanted to see if anyone else here had done this successfully. Thanks!
post Nov 14, 2011 - 5:05 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
people make those tires fit on 9" wide rims wink.gif so i dont see why not laugh.gif
post Nov 14, 2011 - 10:23 AM
spy00005
Joined May 15, '09
From yonkers, NY
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Nov 16, 2011 - 2:42 AM
Hanyo
Joined Aug 16, '03
From Bay area
the 195 is only 10 mm narrower then the stock celica tire. In other words less then half an inch.
the 195/60/15 tire has a 5mm difference in height also. So the difference in the over all tire would be 10mm in height. If you roll both tire standing up next to each other the celica tire would be less then half an inch taller.
Would the tires fit? yes that would fit.
Would you notice the difference? Most likely not.
what are my recommendations? I like to keep with the original specs. But if small things like that dont bug you, and you dont mind having the wrong parts on your car for the next 5 years. Its okay to use that tire size.
post Nov 16, 2011 - 8:56 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Also the speedo issue
when ur going 70, itll be about 1mph off
speedo: 70
your speed: 71
post Nov 20, 2011 - 12:00 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Mine has 195/60/15 tires on it now an they work just fine
only thing I don't like is they look big on the car
94 st hatch my daily driver
n
Lo-Fi Version Time is now: August 27th, 2026 - 1:59 AM
