> replacing lower ball joints
post Nov 14, 2011 - 12:23 PM
conus00
Joined Jul 10, '08
From Tampa, FL
My driver's side is busted and I have few questions:
(1) does anybody have part's numbers?
I have found these on Ebay: http://www.ebay.com/itm/290509051042?ssPag...984.m1423.l2649
(2) Is this doable on the parking lot? Do I need any special tools or compressed air?
(3) Do I need an alignment after the fix?
Thanks!
'94 ST
post Nov 14, 2011 - 12:36 PM
mkernz22
Joined May 10, '10
From MA
1) You can just go to a dealership or autozone and they can look up the parts for you.
2) I don't believe you would need anything special since it's just 3 nuts and a bolt.
3) It would be in the best interest to just to make sure nothing is off and you don't create uneven tire wear.
post Nov 14, 2011 - 1:05 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (mkernz22 @ Nov 14, 2011 - 11:36 AM) *
Hes got it
a couple notes though, its hard to get the upper nut off since the axle is so close. only option there is a wrench, unless you remove the axle, which will require a 30mm socket and a very big breaker bar or air tools. (hint: most consumer impacts arent as strong as a good breaker bar. useful to make most nuts come off faster, and free rotating nuts, bolts, etc)
post Nov 14, 2011 - 3:07 PM
chacha
Joined Dec 29, '05
From So-Cal
use a breaker bar...something like your 2nd pipe for for 3ton jack if you got one...nothing special...those from ebay looks right
post Nov 14, 2011 - 7:54 PM
You'll need a pickle fork to remove the joint from the knuckle.
post Nov 22, 2011 - 5:12 PM
conus00
Joined Jul 10, '08
From Tampa, FL
With my Thanksgiving week and Black Friday schedule I am in no position to fix this myself so I cracked yesterday and decided to have a shop to fix this....
Total tally was $365 (including OEM parts, labor and alignment for BOTH sides). I really wish I had a time to do this myself but with my two jobs it is damn nearly impossible.
I appreciate the inputs of all of you who replied!
Thanks!
This post has been edited by conus00: Nov 22, 2011 - 5:12 PM
'94 ST
Lo-Fi Version Time is now: August 29th, 2026 - 3:43 PM
