Nov 16, 2011 - 7:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
So the question is this. In the book, it only shoes from the pump and before I even get to under the car and make a mess, I want to have the hose ready first. So from the power steering fluid reservoir, which hose is the one that connects to the reservoir above the other one? There is one that goes straight down from the reservoir tank, and there is another that connects from the side above the other one. My guess it is the return hose, considering no hard lines are visible, while the one from the bottom connects to hard lines that are visible. I just wanted to ask someone who has experience with this on these model specific cars.
EDIT: Ok I replaced the hose, I just need to know how to properly bleed the air out. It mentions a bleeder valve but I don't see it. EDIT: No.2 Nvm there isn't one on our cars and I did find it in the book how to bleed. This post has been edited by Random_Stranger: Nov 18, 2011 - 4:08 PM -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Nov 16, 2011 - 9:02 PM
![]() It looks like it's No.9, which is just a hose I gotta replace, which I guess any will do, seeing as it isn't a major specific hose (by ordering or parts check for OEM replacements through Toyota or anything). Looks to be simple enough to find at any place that sells generic hoses. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Nov 16, 2011 - 9:32 PM
If you're replacing number 9, I have one, brand new, OEM, still in the wrapper. Finding the part number on that is a b***. Let me know and I'll send it your way.
Nov 17, 2011 - 10:11 AM
#9 is the return low pressure hose. its the easiest to replace.
Nov 17, 2011 - 12:55 PM
Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
#9 is the return low pressure hose. its the easiest to replace. I bought the large PS hose at autozone for 6 dollars(3ft) and cut it to legth and snugged it over to the side with tie wraps. Just a tip make sure it is PS hose because the hose I put on the 1st time was bleeding PS fluid through it . PS hose seems to be coated with a hard rubber or something. You can see my engine pick of what I mean. This post has been edited by xrav22: Nov 17, 2011 - 12:56 PM |
Nov 18, 2011 - 1:43 AM
#9 is the return low pressure hose. its the easiest to replace. I bought the large PS hose at autozone for 6 dollars(3ft) and cut it to legth and snugged it over to the side with tie wraps. Just a tip make sure it is PS hose because the hose I put on the 1st time was bleeding PS fluid through it . PS hose seems to be coated with a hard rubber or something. You can see my engine pick of what I mean. Thanks. Any chance you know how to bleed this thing? The information I found says it has a bleeder valve, but I don't see it. My book on the car doesn't show it either. :-( -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
| Lo-Fi Version | Time is now: August 27th, 2026 - 4:28 AM |
