> Need help with center sole, Center dash shuts down...
post Nov 19, 2011 - 12:03 AM
hokuten3
Joined May 30, '10
From PA
Hey guys, I need a little help. So like my center sole dash thingy sometimes shuts off(cd play dies, ac/heater dies, and the cig outlet dies) while I'm driving. It would shut down for like 15 mins or so and then it will turn back on again. It's strange....so I'm not too sure whats wrong. Maybe a bad fuse?? Which one would it be though if so? Do you guys have any clues or idea to help me? Thanks!^_^
...5sFREAK...
post Nov 19, 2011 - 2:04 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
sounds like I could be bad ground maybe
94 st hatch my daily driver
n
post Nov 19, 2011 - 8:39 AM
hokuten3
Joined May 30, '10
From PA
Humm... Where do you think the bad ground would be though? 0~o
...5sFREAK...
post Nov 19, 2011 - 10:21 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
that part im not sure since I've nvr had mine apart to see where there all at
maybe someone else will be able to help there
I would do like you said tho an check all the fuses too
n
post Nov 19, 2011 - 2:31 PM
The on and off sounds like a loose connection.
the entire section there works off of one fuse, those are cheap so just replace it as a first step.
Connections behind there include the following:
Cigarette lighter 1 plug
AC unit. 1 plug?
Radio. I think 2 plugs
Hazards. 1 plug
clock. 1 plug
Just pop off the console and make sure its all connected securely.
post Nov 19, 2011 - 10:06 PM
hokuten3
Joined May 30, '10
From PA
I will double check all the plugs tomorrow again. I'm pretty sure that its all good though
...5sFREAK...
post Nov 20, 2011 - 11:13 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the ground in that area may be loose/corroded.
if you pull the carpet up from tunder the center console on the drivers side, it sould be on the "transmission tunnel" there
post Nov 20, 2011 - 12:29 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
QUOTE (playr158 @ Nov 19, 2011 - 2:31 PM) *
AC unit. 1 plug?
iirc the ac unit is 3 plugs
one for most of them, one for the fan, and one for rear defog.
it's been a while since i looked at it though.
post Nov 20, 2011 - 1:49 PM
richee3
Joined Jun 29, '08
From Denver
Does it go on/off when the car jostles or just at random, when the car could be parked?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 21, 2011 - 7:37 PM
hokuten3
Joined May 30, '10
From PA
So I look at my fuses and it's all good. Switch some of my relay fuse too and it's still the same. So far it only happens when I drive at random times. Tomorrow I will check the grounding for that area then.
...5sFREAK...
post Dec 3, 2011 - 10:35 PM
hokuten3
Joined May 30, '10
From PA
soo, it wasnt a bad ground. im not sure what it is anymore. i checked all the grounding and its good. i checked and swap the fuses that i thought would be bad and its still not the problem. but for 4 days straight now it just randomly stopped turning off the center sole...strange...
...5sFREAK...
Lo-Fi Version Time is now: June 23rd, 2026 - 3:24 AM
