> Turbo spooling waaaaaay high!, need boost to come down......how??????
post Nov 22, 2011 - 11:26 PM
injection
Joined Jan 10, '11
From Trail BC
Hello doctors, get your surgical gloves on, because i need help.....
i have asked this question before with no solutions, so i will try again, maybe someone will pick up something i missed, hopefully!!!!!
basically, my 94 celica gt, which i swapped a st205 into, was up and running last may ( 2011 ), ever since then, my boost climbs to around 19-20psi, i have hit fuel cut twice, and smacked my face into the windshield the first time ( seatbelt safety ), wink.gif
anyways, in order to stop hitting fuel cut, i have to let off around 5500-5700rpms, because im right on 18psi, and dont want to keep hitting fuel cut....cant be good kindasad.gif
so heres what ive trouble shooted so far:
hooked air compressor up to wastegate with 15psi pressure....opened perfectly, quickly and smoothly
have an XS Power DP, checked to make sure the actuator clears the DP flange....it does
there is a line that comes off the wastegate and goes behind the bottom of the intake manifold to a sensor called a VSV valve???? i think its called, anyways, hoses are hooked to that and return up front, cant remember where the line goes up front though?? rolleyes.gif
thats about it, kinda outta ideas
I was thinking of purchasing a manuel boost controller, but isnt that for turning up boost, or can you turn down boost as well ( explain please )
If that doesnt work....is there some sort of a bleeder type valve i can buy, to vent some pressure, or does that screw-up vaccum
Thanx, hope one or alot of you have an answer to my problem biggrin.gif 6GC thumbsup.gif
- injection   Turbo spooling waaaaaay high!   Nov 22, 2011 - 11:26 PM
- - Ted95   just buy a manuel boost controller and turn it dow...   Nov 22, 2011 - 11:46 PM
- - Rav4Race   Easiest solution...get a boost controller. I perso...   Nov 23, 2011 - 1:05 AM
- - Neon90424   you may be having boost creep issues which are com...   Nov 23, 2011 - 5:34 AM
- - evo_lucian   I think the problem here is not being addressed. W...   Nov 24, 2011 - 8:59 AM
- - ST205WRC   ok i think most things have been hit but not in an...   Nov 28, 2011 - 1:02 AM
- - Smaay   boost controller is not going to fix this. they ar...   Nov 28, 2011 - 5:52 PM
|- - Rav4Race   QUOTE (Smaay @ Nov 28, 2011 - 5:52 P...   Nov 30, 2011 - 3:51 AM
- - injection   Evo lution, already tried capping off wastgate to ...   Nov 28, 2011 - 6:44 PM
|- - evo_lucian   QUOTE (injection @ Nov 28, 2011 - 6...   Nov 30, 2011 - 9:03 AM
- - CELL_PROTOTYPE_X   Go with an external wastegate...probably your best...   Nov 28, 2011 - 8:03 PM
- - injection   Please explain external wastegate, prototype X, I ...   Nov 28, 2011 - 10:47 PM
- - Smaay   an external wastegate is just that. it looks just ...   Nov 29, 2011 - 4:57 PM
- - Smaay   the only problem changing to external requires som...   Nov 29, 2011 - 5:01 PM
- - injection   My God!!!!!! dont think I ...   Nov 29, 2011 - 9:38 PM
- - injection   Rav, is your boost controller Manuel or electronic...   Nov 30, 2011 - 8:19 AM
|- - Rav4Race   [quote name='injection' date='Nov 30, ...   Nov 30, 2011 - 9:44 AM
- - Rav4Race   Concerning manual boost controllers, not all of th...   Nov 30, 2011 - 9:50 AM
- - Smaay   i have an AVC-R in my 7th gen. again it will only ...   Nov 30, 2011 - 3:50 PM
- - Rav4Race   i dont understand how i made 0.4 bar then:(   Nov 30, 2011 - 4:04 PM
- - injection   Thank-you everyone, for all of your ideas, I belie...   Dec 2, 2011 - 2:37 AM
- - Rav4Race   if u need any help to tune your avc-r, im here:) w...   Dec 2, 2011 - 6:24 AM
- - Smaay   i run a manual boost controller in all my cars. i ...   Dec 2, 2011 - 10:55 AM
|- - Rav4Race   QUOTE (Smaay @ Dec 2, 2011 - 10:55 A...   Dec 3, 2011 - 6:00 AM
- - injection   cool guys, went down the street, actually, went do...   Dec 2, 2011 - 5:13 PM
- - evo_lucian   Divide psi by 14.7 to get boost in BAR. 10 psi ÷...   Dec 7, 2011 - 8:38 PM
- - injection   Sweet, thanx Evo for the formula, wont forget that...   Dec 8, 2011 - 9:39 PM
- - celica95-95   I had same with my st205 , with a 3" down-pip...   Dec 20, 2011 - 7:49 AM
- - delusionz   a cheap fix would be to have a restrictor gasket m...   Apr 9, 2012 - 5:40 AM
- - 3WayStunna   Wow zombie thread. Lol might as well as add my .02...   Apr 9, 2012 - 9:28 AM
- - delusionz   in my case, when i had the factory turbo and facto...   Apr 23, 2012 - 6:25 PM
Lo-Fi Version Time is now: August 31st, 2026 - 12:41 AM
