> Sway bar polyurethane bushings, Anyone found some that fit our old celicas??
post Nov 29, 2011 - 7:34 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
I have searched, and searched. No clear answer as to the size of our stock sway bars, but I seem to see that they may be
F: 18mm and R: 16mm, can this be confirmed?
Also, I see that the brand Prothane makes universal poly bushings.
I hope you can see where I'm going with this.
Will these fit? or is the length measurement off? Or Can anyone direct me to some that are known to fit?
I would measure my bushings but they are disintegrated pretty badly to the point I am not sure I would get a proper measurement. Worst case scenario, I buy squishy OEM rubber replacements.
FRONT 18mm
REAR 16mm
My F/S Thread!
Ferdi says (11:29)
- samir0189   Sway bar polyurethane bushings   Nov 29, 2011 - 7:34 PM
- - RabidTRD   Energy Suspension makes a set that fit perfectly. ...   Dec 3, 2011 - 12:46 PM
- - RabidTRD   OK, part number that fits perfect from Energy Susp...   Dec 3, 2011 - 10:31 PM
- - easternpiro1   good stuff, from what i hear this is a great inves...   Dec 4, 2011 - 1:14 AM
- - samir0189   QUOTE (RabidTRD @ Dec 3, 2011 - 10:3...   Dec 4, 2011 - 9:29 AM
|- - easternpiro1   QUOTE (samir0189 @ Dec 4, 2011 - 10...   Dec 4, 2011 - 7:56 PM
- - samir0189   The front sway bar on my car is 20mm. I will look ...   Dec 4, 2011 - 3:50 PM
- - samir0189   Seems like the part number for the front would be ...   Dec 4, 2011 - 6:14 PM
- - richee3   I'm tempted to replace several bushings in my ...   Dec 4, 2011 - 10:20 PM
- - Malhar95   how much do these cost avg.? im not tracking or sw...   Dec 5, 2011 - 12:58 AM
- - samir0189   QUOTE (easternpiro1 @ Dec 4, 2011 - 7...   Dec 5, 2011 - 1:52 PM
- - RabidTRD   One thing I will suggest, and highly recommend doi...   Dec 8, 2011 - 5:09 PM
- - samir0189   I received the bushings today actually. I'll p...   Dec 8, 2011 - 5:44 PM
- - RabidTRD   I'd say to take a piece of sand paper and wrap...   Dec 8, 2011 - 7:57 PM
- - samir0189   Well. They were a bit of a pain to install, yes. O...   Dec 10, 2011 - 7:26 PM
- - RabidTRD   Omg your bars have absolutely no rust on them at a...   Dec 10, 2011 - 11:17 PM
- - Ted95   nice work! anxious to hear how the car rides w...   Dec 12, 2011 - 11:09 PM
- - samir0189   QUOTE (RabidTRD @ Dec 10, 2011 - 11...   Dec 14, 2011 - 12:20 PM
- - SupraKid   Samir why did you get red bushings appose to black...   Dec 14, 2011 - 10:29 PM
- - RabidTRD   Do the colors really make a difference? I got blac...   Dec 15, 2011 - 7:17 AM
- - SwissFerdi   $35 you say, huh? I may has to invest in thes...   Dec 15, 2011 - 8:16 AM
|- - Spider77   QUOTE (SwissFerdi @ Dec 15, 2011 - 9...   Dec 28, 2011 - 8:17 PM
- - samir0189   @andrew - 1. Didn't know the color made a diff...   Dec 15, 2011 - 10:20 AM
- - SupraKid   The more lube the better I always say.   Dec 15, 2011 - 12:52 PM
- - RabidTRD   Omg lmao! So then I could have run my black o...   Dec 18, 2011 - 1:22 PM
- - mkernz22   ebay! http://www.ebay.com/itm/CELICA-ST202-ST...   Dec 20, 2011 - 3:09 PM
- - SupraKid   uhm...Kern those are more expensive..   Dec 20, 2011 - 3:42 PM
- - mkernz22   i know, but it's still another option   Dec 20, 2011 - 5:36 PM
- - SupraKid   Will be installing my set and kirk mounts tomorrow...   Dec 28, 2011 - 9:27 PM
- - stephen_lee   GT and ST have different sized sway bars IIRC.   Dec 29, 2011 - 9:56 AM
|- - doctavic   QUOTE (stephen_lee @ Dec 29, 2011 - 10...   Nov 20, 2012 - 11:37 PM
- - SupraKid   These things are SWEEEEEEETTTTTTT. Definitely a di...   Dec 31, 2011 - 10:06 PM
|- - Ted95   QUOTE (SupraKid @ Dec 31, 2011 - 10...   Dec 31, 2011 - 11:43 PM
- - SupraKid   Yea and I got the black ones. With lube they go on...   Jan 1, 2012 - 2:38 AM
|- - Ted95   QUOTE (SupraKid @ Jan 1, 2012 - 2:38...   Jan 1, 2012 - 12:53 PM
|- - RabidTRD   QUOTE (SupraKid @ Jan 1, 2012 - 2:38...   Jan 2, 2012 - 1:15 PM
- - RoyO   Anyone installed these? http://www.ebay.com/itm/ST...   Jan 1, 2012 - 4:56 PM
- - SupraKid   *Couch cough searchyoumuthafugginnoob cough cough*...   Jan 1, 2012 - 5:26 PM
|- - RoyO   QUOTE (SupraKid @ Jan 2, 2012 - 12:2...   Jan 2, 2012 - 3:09 AM
- - Spider77   Ordered a set......on an off topic, amyone try the...   Feb 25, 2012 - 8:01 PM
- - Spider77   Rear sway bar for a GT is 17mm (according to my ol...   Mar 6, 2012 - 2:30 PM
- - SupraKid   My thoughts exactly about the 7th gen short shifte...   Mar 6, 2012 - 3:59 PM
- - jordisonjr   Has anyone used these sway bar bushings: http://ww...   Apr 1, 2012 - 11:34 AM
|- - mkernz22   QUOTE (jordisonjr @ Apr 1, 2012 - 12...   Apr 4, 2012 - 10:12 AM
- - jordisonjr   ohhhh haha my bad. did you end up getting these? o...   Apr 4, 2012 - 12:43 PM
- - jordisonjr   Do you have to jack up the car to replace the rear...   Apr 21, 2012 - 4:19 PM
- - trdproven   just following up on this thread, is it confirmed ...   Apr 27, 2012 - 6:54 PM
- - trdproven   Im guessing the fronts need 20mm bushings and best...   Apr 30, 2012 - 5:28 PM
|- - Spider77   QUOTE (trdproven @ Apr 30, 2012 - 6...   Apr 30, 2012 - 7:15 PM
- - jordisonjr   I just put in the 16mm on the rear, with the brack...   Apr 30, 2012 - 8:59 PM
- - trdproven   did the ES bushings change the feel from a daily d...   Apr 30, 2012 - 10:43 PM
- - jordisonjr   I wasn't able to finish installing them yet. I...   Apr 30, 2012 - 11:31 PM
- - Syaoran   PROPER SIZES for a GT (ST204): 20mm front, 17mm re...   Nov 21, 2012 - 12:53 AM
- - doctavic   16 it is for me then (AT200), thank you Syaoran......   Nov 21, 2012 - 7:11 AM
|- - Syaoran   QUOTE (doctavic @ Nov 21, 2012 - 8:1...   Nov 21, 2012 - 2:58 PM
|- - doctavic   QUOTE (Syaoran @ Nov 21, 2012 - 2:58...   Nov 29, 2012 - 5:45 PM
- - RabidTRD   I own a ST204 and have 16mm rear bars.   Nov 22, 2012 - 1:55 PM
|- - Syaoran   QUOTE (RabidTRD @ Nov 22, 2012 - 2:5...   Nov 23, 2012 - 2:35 PM
- - BillyM81   My black 94 gt and my yellow parts car both have 1...   Nov 23, 2012 - 3:39 PM
- - RabidTRD   My GT is a 94. It never had a gap on the bushing. ...   Nov 24, 2012 - 10:28 PM
- - delusionz   you guys have 20mm front??? what the hell!...   Nov 26, 2012 - 10:46 PM
|- - BonzaiCelica   QUOTE (delusionz @ Nov 26, 2012 - 11...   Nov 27, 2012 - 1:18 PM
- - delusionz   i wonder if the front bar from an st204 would fit ...   Nov 27, 2012 - 3:38 PM
- - Syaoran   AWD cars are similar to FWD cars in that they tend...   Nov 28, 2012 - 2:59 AM
- - delusionz   ISH! the rear swaybar will lift the outter wh...   Nov 28, 2012 - 2:47 PM
- - SwissFerdi   Having the rear dampers harder for more traction m...   Nov 28, 2012 - 3:05 PM
- - Syaoran   Stiffer springs in the rear help to both improve t...   Nov 28, 2012 - 3:30 PM
- - BonzaiCelica   it is very possible to fit the st204 sway bar on s...   Nov 29, 2012 - 3:07 AM
- - jordisonjr   Torching a sway bar, and bending it to fit seems l...   Nov 29, 2012 - 2:06 PM
- - RabidTRD   Is anyone else having crazy loud creak noises? Did...   Nov 30, 2012 - 9:50 PM
|- - Galcobar   QUOTE (RabidTRD @ Nov 30, 2012 - 7:5...   Dec 1, 2012 - 11:00 AM
- - SwissFerdi   Rubbing on the frame somewhere, I bet.   Nov 30, 2012 - 11:03 PM
- - jordisonjr   ^ This.   Dec 1, 2012 - 3:45 PM
- - richee3   I've had mine on for around 7-10k miles now an...   Dec 1, 2012 - 11:34 PM
|- - Galcobar   QUOTE (richee3 @ Dec 1, 2012 - 9:34 ...   Dec 3, 2012 - 6:41 AM
- - BonzaiCelica   i had a annoying creak on teh front sway bars, but...   Dec 2, 2012 - 2:44 AM
- - RabidTRD   I've lubed the hell out of them... I used the ...   Dec 4, 2012 - 2:57 PM
- - Galcobar   I relube mine about that, but I suspect that's...   Dec 4, 2012 - 6:47 PM
Lo-Fi Version Time is now: August 9th, 2026 - 12:37 PM
