> Replacing front bearings
post Dec 16, 2011 - 3:04 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
My left front bearing is done. I have replaced rear bearings in another car before...is the process any different for the front? I shouldnt need a press if I purchase the entire hub correct? I assume I would remove the brake calipers then the rotors then the 3 screws that hold the hub then the center one?
post Dec 16, 2011 - 3:13 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
It's a press in bearing... You've got to have it pressed out and a new one pressed in. The front on this car is different than the back. The rear has a bolt on hub assembly. The front is a knuckle, which the bearing gets pressed into, and then the hub pressed into that.
Lo-Fi Version Time is now: August 26th, 2026 - 3:17 AM
